BIKELAND > FORUMS > ZX12R ZONE.com > Thread: PCIIIR Timing Settings? NEW TOPIC NEW POLL POST REPLY
KawRider
posted November 23, 2001 12:43 AM
Ive got my new Hindle exhaust system installed, and Im about to install my PC-IIIR. I used the Muzzy Hindle pipe map, modified with Cliff Crandal's low throttle position smoothness fix. I have also used the timing settings from the Muzzy Race map courtesy Easy. Is this map safe to my motor when running pump (premium) fuel? It gives a full 5 degrees advance from 7500RPM to 10,500RPM. I definately don't want to hurt my motor.
Thanks!
Tim
0012R
cliffrandall
posted November 23, 2001 06:16 AM
5 degrees is perfect my friend, enjoy it.
Cheers,
Cliff
silver01bullit
on here too much
posted November 23, 2001 06:18 AM
it will be fine cause once you get the motor running at that high of an rpm the spark needs more of a head start. Does the map start off at little advance, maybe 0-2 degrees and then work up to 5 degrees? That's because the spark doesn't need as much of a "head start" at lower rpm's as it would at higher rpm's. Hope this helps
  Ignore this member    Click here to send silver01bullit an AIM message.
KawRider
posted November 23, 2001 06:25 AM
Timing
Yes the advance progressively increases to a max on 5 degrees.
Thanks for the info.
Tim
0.2198760509491 seconds processing time
