BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Modifications done so far on your 12 NEW TOPIC NEW POLL POST REPLY
harryzx-12
posted November 22, 2001 11:54 PM
1. Akropovic-Ti-Oval exhaust
2. PC-111 Custom map
3.Muzzy Timing advancer set at 5 deg
4.Kleen-air system removed,Muzzy block off plates installed
5.Heat blanket.
6.Pingel kill switch
7.Suspension set up by GMD computrack- Penske 8620 rear shock with spring to match my weight.
8.Front forks revalved and heavier springs to match my weight.
9. Kennedy adjustable links
10. Goodridge -2 SS brake lines front and rear.
11. HH pads on fronk, Kevlar on rear
12.FSD undertail
13.Hans carbon fibre - ram air covers,ram air,ashtray,and chainguard.
14. Yellow box Recalibrated 20%
15. 17t countershaft sprocket (New top speed , a true 183 mph)
16. Falicon Billet clutch basket.
silver01bullit
on here too much
posted November 23, 2001 06:23 AM
I'm sure I'll leave something out, but here it goes....
1. Muzzy clutch
2. Akrapovic with ti can
3. Muzzy alum fan
4. Muzzy block offs
5. Muzzy links
6. 17/48 gearing
7. Stock Air Filter mod
8. Timing Mod
9. Dropped 3/4" at forks
Winter mods: brake lines/pads/fluid, Damper???, Rennsport tires, after that learning how to ride better!!!!
  Ignore this member    Click here to send silver01bullit an AIM message.
posted November 23, 2001 06:33 AM        Edited By: swft on 23 Nov 2001 06:35
Red 12.7:
1. Exhaust: Muzzy full Ti
2. Mapping: PC-111r Custom map
3. Intake: Kleen-air system removed,Muzzy block off plates installed
5. Exhaust: Heat blanket.
6. Safety: Pingel kill switch
7. Susp: Shock set up by Ohlins USA Rep- Ohlins with spring to match my weight.
8. Susp: Front forks revalved by RaceTech and heavier springs (1.0 kg/mm) to match my weight.
9. Brakes: Goodridge -2 SS brake lines front and rear.
10. Breakes: HH pads on fronk, Kevlar on rear
11. Body: FSD undertail
12. Body: Hans carbon fibre - ram air covers,ram air,ashtray,and chainguard.
13. Instr: Yellow box Recalibrated 20%
13. Clutch: Muzzy clutch / springs
15: Motor: Muzzy 1270, custom porting on head.
16: Body: ZG Double Bubble Smoke
17: Body: '00 ZX9 Mirrors
18: Body: LP Tank cover
Silver 13.5:
1. Exhaust: Muzzy full Stainless
7. Susp: Kennedy adjustable links
8. Breakes: HH pads on fronk, Kevlar on rear
9. Clutch: Muzzy clutch / springs, billet basket
10: Motor: Muzzy 1270 top end, custom porting on head, custom crank.
11: Susp: Schnitz strap on the forks
0.31959199905396 seconds processing time
