BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Do12 wheels fit a 14 NEW TOPIC NEW POLL POST REPLY
capt10ed
posted December 24, 2011 09:32 AM
I know I should not ask
but
Do the 04 12r wheels fit a 14R?
and 204.5 in the mile.
posted December 24, 2011 09:35 AM        Edited By: Shane661 on 24 Dec 2011 17:37
It has been stated that 14/14R wheels are the same mounting details ("swappable"), so based on that:
The front 12R wheel will not fit, rotor spacing is wrong and there is no easy or mildly difficult fix.
The rear will bolt up no problem using the stock 12R rear rotor (rotor bolt pattern is different from the 14). If you have a smaller wave-type rotor, you can try using the 12R brake hanger. I have not checked it, but it looks like it should swap over. If that does work, you would need to make some sort of hole in the hanger for the wheelspeed sensor (2012 14R only).
0.34181904792786 seconds processing time
