BIKELAND > FORUMS > ZX12R ZONE.com > Thread: SHIT NEW TOPIC NEW POLL POST REPLY
blkrnbw
posted November 22, 2001 01:27 PM
SHIT
Welp its not the battery, got it all setup to jump (exactly as it is in the book, yes found mine) still no power. Checked main fuse and all other fuses, all look good. Bike has a PCIIIR not sure if that can cause a power outage. But nothing happens at all when key is turned, no gauge check no nothing. Any clues anyone. Yes thank god bike is under warranty.
Brian
harryzx-12
posted November 22, 2001 01:34 PM
Sometimes they (the dealer) don't hook the cables up to enable you to jump start the bike.
blkrnbw
posted November 22, 2001 01:45 PM
Hooked that up before, still nothing.
harryzx-12
posted November 22, 2001 02:53 PM
Sorry it didn't help.If you would please post the problems solution when you find it.Thanks,You may help one of us should it ever happen to them.
blkrnbw
posted November 22, 2001 03:02 PM
i remember someone talking about their PCIIIR going bad, could this cause a total power shutdown?
Brian
SleezyRider
Mean Motor Scooter
posted November 22, 2001 04:49 PM
Some of the PC111R's have done some strange things in the past. Only one way to find out. Remove the tank and reconnect the original connectors. Also detatch the red power line and reconect the original line.
Check the lines very carefully and see if there are cuts in the cables. I have seen this before, so look close.
Let us know if this helps...
0.24795699119568 seconds processing time
