BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Muzzy Block off plates/Kleen air removal NEW TOPIC NEW POLL POST REPLY
KawRider
posted November 22, 2001 10:23 AM
Well Ive got my Hindle system installed, and it is great. My next step is to install my Muzzy Block-off plates and PCIIIR. My question is this:
Do the block-off plates basically eliminate the Kleen Air system? Or must I do this procedure in ADDITION to the Block off plates?
Thanks!
Tim
00 12R
posted November 22, 2001 10:41 AM
They eliminate the Clean Air system. You *MUST* plug the resulting hole in the airbox/frame when you pull the hose going from the clean air system valve to the airbox/frame. There's a vac fitting that needs to be capped off as well. It's pretty basic tho, nothing too scary.
0.24721908569336 seconds processing time
