BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2003 zx12r ecu help NEW TOPIC NEW POLL POST REPLY
burn
posted June 18, 2011 03:06 PM        Edited By: burn on 18 Jun 2011 23:35
2003 zx12r ecu help
accidently cut my wireing harness(looks great without the rear fender though) fixed wires now get nothing could that have killed my ecu? ingnition was off when i dit it ps checked all fuses they are all good
burn
burn
posted June 18, 2011 03:29 PM        Edited By: burn on 18 Jun 2011 23:33
How can you find out if your ecu is bad local kawi dealer said he cant. is that true?
burn
tuusinii
posted June 19, 2011 10:42 PM
Get the service manual. There are instructions. It starts by checking that the ECU has power and goes on after that. There are couple simple tests. And first double check that You corrected everything right!
burn
posted June 20, 2011 03:26 AM
Thanks Tuusinii will do that connections are good it was only two wires that got cut through red w/gold and blue w/white
burn
Michaels12
posted June 20, 2011 04:06 PM
blue /white are inlet air pressure sensor & atmos air pressure
red/yellow ( no gold listed) looks like dianostic terminal
burn
posted June 30, 2011 03:51 AM
Thanks everyone for your help. The E.C.U was fried. New one in back on the road!!
burn
tuusinii
posted June 30, 2011 04:51 AM
Good You got it figured out. Now just keep the right side up!
0.3652138710022 seconds processing time
