BIKELAND > FORUMS > ZX12R ZONE.com > Thread: get rid of muzzy NEW TOPIC NEW POLL POST REPLY
miketmmns
posted June 06, 2011 01:37 PM
get rid of muzzy
If I ditch the Muzzy and go with another exhaust will the hunting at idle go away. I've tried everything listed that might help it and its still does it. I'm to the point that if I can't fix it I'm going to sell it and let someone else worry about It
posted June 06, 2011 02:09 PM
Its not worth it...Take the PC out then the idle will be smoother & raise the idle to 1,300...
Unless you can find a good used Akrapovic or Yoshimura...
If not then just deal with it like most people do with a muzzy on a 12...The car guys like the idle, they think you have a big motor in there...Back in the day I use to go to the local car/bike show with my 2000 12, it was slammed had my DragRace #s on each side, removed the entire baffle and cruised with the loping idle...Nobody ever wanted to race me...
Paul2281
posted June 06, 2011 02:26 PM
Did you try adding fuel....If I add a bunch of fuel to mine it goes away....But I kinda like it so I keep it like it is....A dyno guy told me its doing that because it`s lean....He said to add a couple of bars on the front of the PC.....
miketmmns
posted June 06, 2011 06:54 PM
I tried to add fuel and it actually got worse. I took the PC off of it tonight and it did help.
0.27833294868469 seconds processing time
