BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 none start problems NEW TOPIC NEW POLL POST REPLY
harley1300
posted May 03, 2011 12:29 PM
I have just purchased a 2003 zx12 b model, it was running fine until today, went out to start and all I get is a relay click and full pump cutting in as I depress the start button?. I have check the battery voltage and is fine, so on reflection I have owned the bike a day and is showing a problem already.
I turn on ignition depress start button get a relay click and fuel pump activates, but no starter motor or turning over, just fuel pump cuts in as you depress the start button?
Any help will be great.
Russ
r neve
ZXLNT
posted May 03, 2011 02:09 PM
Did you check the battery voltage under load. Put the voltmeter across the battery terminals and then try to start it. See if the battery voltage sags under load..
twista
" Get up, and Stay up ! "
posted May 03, 2011 05:31 PM
you should get fuel pump activation on truning the key NOT when you hit the starter button??? also i would throw another battery in it and see what she does,, you evidentally have a power connection if you hear the clicking from the relay.
0.22192287445068 seconds processing time
