BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 speed sensor NEW TOPIC NEW POLL POST REPLY
teamtaz
posted May 03, 2011 06:25 AM
zx12 speed sensor
does a vehicle speed sensor fault ( code 24),have any interferance with ecu, ie get you hamoe mode, limiting power, engine fitted in autograss car and i have no speed sensor fitted,cheers
shiphteey
posted May 03, 2011 11:23 AM
year?
Gemini Motorcycles
teamtaz
posted May 04, 2011 01:13 AM
sorry 2002 reg think its a b2 model,cheers
tuusinii
posted May 04, 2011 10:32 PM
Yes. It will impose lower RPM limit if there's no speed sensor signal to the ECU. As it's the earlier version, it's easiest is to make a feke signal from RPM signal or buy Muzzys Bonneville box (which makes the same). After that there's no limit. There are instructions how to build the circuit with 2 transistors and couple resistors - not very difficult...
0.22823619842529 seconds processing time
