BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 forks and calipers? NEW TOPIC NEW POLL POST REPLY
KINGKWIK
9.36@ 149.23
posted April 17, 2011 11:48 AM
Does anyone know if the forks from an 05 will fit into the triple clamps of an 01,,, zx12?
Also will the calipers from a zx14 bolt up to the forks of an 05 zx12??? Looking to upgrade my suspension and brakes.
If it has wheels or tits its bound to be trouble!!
WARBIRD
posted April 17, 2011 01:08 PM
Sounds like a great way to go about it............ Hope you get some good feedback, I would like know for my 00 as well.
I'd Rather Be Roadracing.
capt10ed
posted April 17, 2011 06:25 PM        Edited By: capt10ed on 18 Apr 2011 02:26
The calipers from the zx14 do bolt right on the 04 and later 12's.... I installed as set on my 04 zx12 along with the 14's master cylinder. A tremendous improvement over the stock system,
and 204.5 in the mile.
twista
" Get up, and Stay up ! "
posted April 17, 2011 06:59 PM        Edited By: twista on 18 Apr 2011 03:09
yep it works,, its what i run... Brembo MC with Motul fluid,, Goodridge Braided lines and a Pazzo Shorty lever to match the other side made by Brembo.. HH EBC pads,, Zx14 Calipers and 04 Radial Forks and Rotors.. thats all you need! ] forgot to mention this is a Brembo 19X20 MC and this setup is so good i wouldnt change a thing!
WARBIRD
posted April 18, 2011 11:59 AM
YES!! Thanks capt10ed an twista............... More pics please........ Would like to see the 14 master cyl too.
WARBIRD
posted April 18, 2011 12:58 PM
twista...........are those A1 wheels and rotors?????? No changes required?
WARBIRD
posted April 18, 2011 01:01 PM
Just checked mine......they are different. {mine are original] So do i need to change the wheels or rotors? Looks like the axle, collar and spacers are all the same part #'s 2000-2005
WARBIRD
posted April 18, 2011 01:35 PM
OK...........I got in my file cabinet and got the 12R brochures out. The 2000-2003 12's have 320mm rotors. The 04-05's have 300mm rotors. So I could simply shim the 14 calipers 20mm on my 00.......Sound right???
Bolt up the 04-05 forks, put the wheel back on and shim the 14 caliper's 20mm. Then install the 14 master cyl and spiegler brake line's and good to go...........
WARBIRD
posted April 18, 2011 01:40 PM
And after all that I see where twista used the different rotors........
posted April 18, 2011 01:42 PM
If the rotor spacing is right on the wheel, all you would need are 10mm shims to make up for a 20mm differenence in rotor size.
I have no way of knowing how the 12R 320mm rotors compare to the 300mm 12R rotors as far as carrier/rotor spacing goes.
WARBIRD
posted April 18, 2011 01:55 PM
Sent you a pm Shane. Thank's for the info. The axle, and all the spacer's ( left, right and in between the bearings are all the same part # for all years. So is the collar and the spacer's betweem the rotors and wheel.
WARBIRD
posted April 18, 2011 01:57 PM
Kawasaki call it a Gasket,Disc Plate................ All same part #s.......
WARBIRD
posted April 18, 2011 02:16 PM
The black wheels are the same part# for the 2000 and 2005.....
twista
posted April 19, 2011 10:20 PM
if you re read the post above,, i stated that i am wearing 04 rotors,, bolted them up to the 2000 wheels! DONE>>>>>>>. no spacing direct fit and finish...
WARBIRD
posted April 20, 2011 08:05 AM
Quote:
And after all that I see where twista used the different rotors.........
5 post's above your last............
Trying to see if I can use your setup with the stock rotors...........looks like a 10mm spacer will do the trick. Thanks for posting up the info and pics.
KINGKWIK
9.36@ 149.23
posted May 03, 2011 04:11 PM
so I bought a set of 2004 forks for my 01... to my complete suprise.....the 04 forks are 1 3/4 inches longer than the 01. My 01 was used when I bought it and the 04 forks are used as well... so I am assuming that either set of forks were modified????? can't see the to years having that big of a difference in fork length????? anyone know???
twista
posted May 04, 2011 05:53 PM
01 probably had the spring cut to lower it ??? pull a cap and have a look....
0.28533506393433 seconds processing time
