BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Extra wire in Battery Compartment? NEW TOPIC NEW POLL POST REPLY
KawRider
posted February 06, 2003 01:44 PM
I came back from Kosovo this week, and decided to charge up/start up my 2000 ZX12R. I have never really messed with the battery much in the past. There is a long large wire on top of the battery that kinda hangs there. What is this wire for, and is it supposed to be conected to anything? It was dark in my Garage when I started the dissasembly process, abd I just want to make sure I put it back together right. Im thinking it doesn't hook up to anything. It looks like a battery cable, and has the red protective insulation cover thingy.
Thanks in advance for the help,
Tim
Black ZX-14
your car is slow
Fuck Nitrous...Got Boost?
posted February 06, 2003 01:47 PM
Jumpstart/charging I believe.
Do not taunt happy fun ball!
RAC4IT
Bergie
posted February 06, 2003 03:32 PM
That is the jump cable; the diagram on the inside of your battery cover will explain. It's not connected from the factory, but I suggest that you do connect it and safely tuck the insulated connector out of the way. In the event you need a jumpstart then you will not have to pull the entire battery tray out to reach it.
redelk
Please... speak to the hand.
posted February 06, 2003 08:55 PM
More info on that cable can be found here....
http://www.bikeland.org/board/viewthread.php?FID=1&TID=6039&set_time=
-Ernest Hemingway
Hells Dark Lord
living life, and loving it.
posted February 06, 2003 09:11 PM
and roger that, I have mine under my seat, I need to hook it up when I get home...
posted February 07, 2003 07:22 AM
This brings me back to one of my plans on still on "the back burner".... which is to eliminate the battery tray altogether and to install a battery under the seat where it belongs... then you could put something else in that old space, like spare gloves er a gun.... anyways... there are several small, light weight batteres out there that I am looking at... hopefully I will get around to it someday...
redelk
posted February 07, 2003 12:50 PM
If your packing you gun, Fish, don't forget to make room for your worthless POL or if your a really good canook and behave, your PAL.
-Ernest Hemingway
0.26233601570129 seconds processing time
