BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Great Expectations.... NEW TOPIC NEW POLL POST REPLY
Megabyte
posted January 26, 2003 02:11 PM
Great Expectations
As those of you who frequent this board know, I've been on the fence over a year trying to decide between a 1270, 1361, or turbo. I finally took the plunge, and paid my dues to step up to the 1361 club. It will probably be a couple months before my 12 is back on the road and I'm able to evaluate the wisdom of my decison, but I have to say my expectations, and those of my
"in the know" friends are very high; It feels like waiting for Christmas. Anyway, I've got the best mechanic I know doing the work, and a trusted board member overseeing the job, so, I don't see how I could have a better combination for success.
deathpulse
posted January 26, 2003 02:18 PM
GOOD LUCK MEGABYTE!! let us know how it works out. Me, I'm still trying to get used to the power of my stocker 2000!!!! (well, if K&N's, PC-IIIr, no Kleen air, and Muzzy full exhaust count as a stocker). I think I may be able to get 180 Hp out of her this summer, what kind of numbers are the 1361's putting out? Must be a CRAZY ride! KEEP US POSTED!
RAC4IT
Bergie
posted January 26, 2003 02:24 PM
Good luck with it!
Hells Dark Lord
living life, and loving it.
posted January 26, 2003 02:30 PM
Good Luck Mega...... I looked into a 1270 kit but decided the money I spent on teh extended warranty would be wasted and I am not into throwing money away...so I will wait.....let me know how she turns out for ya
posted January 26, 2003 03:57 PM
you will NOT regret it!!!!
I assume you also:
have PC3r
have a good pipe
doing the adj cam sprockets
fresh OEM rods or at least new rod bolts
having the trans closely inspected/freshened up
dissamble head, clean valve facings
optional but recommended by some:
stronger valve springs
billet cam chain tensioner
light clean up of head
GO FOR IT!!!! I can smell that tire going up in smoke!!!!
posted January 26, 2003 06:26 PM
Yer gonna love it!
Megabyte
posted January 26, 2003 10:49 PM
I assume you also:
have PC3r:
Yes
have a good pipe:
Yes, Full Akro
doing the adj cam sprockets:
Yes
fresh OEM rods or at least new rod bolts:
I assume new rod bolts only.
I considerd the Carillos, but decided to stick w/stock.
having the trans closely inspected/freshened up,
Yes all moving parts will be weighed, balanced,and super teked?
dissamble head, clean valve facings:
Yes
stronger valve springs:
Don't think so
billet cam chain tensioner:
Yes, manual tensioner
light clean up of head:
Yes
In addition: Crankcase ventilation mod. Muzzy Fan, & Velocity Stacks. Heat Blanket and ZX6r clutch springs. After my 1k breaken I'll probably get the full muzzy clutch upgrade.
Thanks, I can use all the MOJO I can get
Megabyte
posted January 26, 2003 10:50 PM
Yer gonna love it!
Thanks SWFT, coming from you, that means alot
Zhooligan
Post Whore Extraordinaire!
posted January 27, 2003 11:16 PM
Don't forget you'll be losing the counter balancer (less rotating mass). You might want to think about the clutch fan mod as it can't be any easier to do then when the engine is out!
future; -- Youth is forever.
Megabyte
posted January 28, 2003 08:41 AM
yES, I asked Mike to include the Muzzy Fan and the Fan Switch Mod.
Thanks, for reminding us...
posted January 28, 2003 09:30 AM
I did the fan switch mod on Zhooligan's bike. Was pretty simple and clean to do. The fan power is really close to the harness that comes down from the left control cluster.
Megabyte
posted January 28, 2003 12:41 PM
and what a clever little mod it is too ....
posted January 28, 2003 05:32 PM
Not as clever as the ejection seat I'll wire in for ya...Free of charge!
Zhooligan
posted January 29, 2003 07:07 PM
The crank has been shipped along with the rods to the (spud boy) crank guy, the block is off to millinium, pistons are in hand, all of the other assorted moving parts have been shipped for superteching.
The valve cover gasket had been leaking for quite awhile. Bit of yuckie mess. Of course everything has and will be clean as a whistle. So you are officially like most in the works 1361's. Spread out to all corners of the country! Velasco says ZX12 engines get more airmiles then any other engine except for Ducatis.
So you can officially say you are in the waiting mode!!
Megabyte
posted January 29, 2003 07:32 PM
Great news! I'm wondering what the crank & bearings looked like after 12k miles?
I'm afraid we can thank another dealer (located in Lynnwood) for that mess, sorry guys....
Do the air miles I logged while riding count?
Thanks for the update!
Megabyte
posted January 29, 2003 07:34 PM
I'll remember to wear my parachute.
Megabyte
posted March 14, 2008 06:55 AM        Edited By: Megabyte on 14 Mar 2008 07:57
Just dawned on me that I never posted my results.
212 rwhp 123.8 ft/lbs torque
Mods
1. Hotbodies undertail w/signal lights
2. Carbon Fiber Hugger, Carbon Fiber Front Fender
3. Lightweight Aluminum PM Wheels
4. Akro full exhaust system
5. Muzzy Aluminium fan
6. Muzzy Clutch (billet basket and hub)
7. Muzzy 1361 kit, installed by MVR (Mike built race engines for Ducati)
8. Ported and polished flowed heads by MVR
9. Balanced and Super teched engine and transmission
10. Counter balancer removed
11. Muzzy adjustable cam sprockets
12. Power Commander IIIr
13. Zero Gravity Double bubble
14. Stainless steel braid brake lines front
15. BMC Race Air filters
16. Muzzy High flow fuel pump
17. CF exhaust hanger
18. Scott's Steering damper
19. Muzzy Gold Stacks
20. Schnitz Racing adjustable Aluminium Kick Stand
21. Titanium Rotor bolts.
22. Crankcase ventilation mod
23. Scott's billet Oil Filter
24. Clear tail light with signal lights
25. Rev limiter mode adds 580rpm to the 12's 11.6k rev limiter.
26. ABM Stainless Steel Front and Schnitz Rear Wave Rotors
ABM Peak Stainless Steel Brake Rotor 320mm Full Floating. Ultra lightweight stainless steel rotors, with titanium anodized floaters & carrier. This design uses a new proprietary blend of stainless steel that performs as well as iron with all the benefits of stainless
twista
" Get up, and Stay up ! "
posted March 14, 2008 09:03 AM
Looks like we got another DARK WING DUCK LOL,,
0.23942303657532 seconds processing time
