BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Erractic Idleing NEW TOPIC NEW POLL POST REPLY
Janinja
posted October 13, 2010 07:52 PM
Erractic Idleing
So, once my bike is fully warmed up and ive been cruising a while, ill come to a stop sign or stop light and i noticed that the idle is around 1.4-16k bouncing back and forth. Any indication the cause of this? I have a whole laundry list of parts to put on my bike in the garage but as of right now there isnt anything modified to the bike. The only issue that is a known factor is the valve gasket has a slight slight leak in it, however the idleing didnt occur until just recently and the gasket has been leaking for a week or so.
Janinja
posted October 16, 2010 04:40 AM        Edited By: entropy on 16 Oct 2010 12:41
have you tried adjusting the idle down a bit with the idle screw?
fast idle lever?
cable hung up?
navpreet318
one crazy 12
posted November 10, 2010 08:39 AM
Yes lower the idling to about 1 k after warming up the bike properly.thats where the idle should be once warmed up.Also is the erratic characteristic feeling throughout the rev range?
If yes then its probably plugs.i found the hard way after changing the battery,cleaning the injectors by taking them out and cleaning the tank and the fuel pump as well.so much for just changing a set of stupid plugs.
2005 ZX-12R,Arata Full Ti, PC3,Gillis
Rearsets,Muzzy Velocity Stacks,BMC
Race filters.One Crazy 12
Stuart Racing
N.H.R.A . Dragracing.
posted November 10, 2010 01:37 PM
What is your setup...Power Commader,air filters,ect.ect....????
Sometimes the ECU or PC is "searching"/hunting for air or fuel....If you add some fuel to it on the low side it seems to calm it down a lot.....JMO....
wylde
posted November 10, 2010 01:54 PM
or you can do a pilot jet mod,, alot seem to think it works...
There you go again,,NOT being aware of yourself !
0.23256516456604 seconds processing time
