BIKELAND > FORUMS > ZX12R ZONE.com > Thread: high out put stick coils NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted October 13, 2010 11:54 AM
was at the toyo nats the past weekend and noticed that MSD has high out stick coils for cars. well with out having one of mine with it sure looks like they are real close to out denso coils.
then the next question it will the circuit in the ecu be able to handle it?
NOX
PMRA / TMRC Super Street 4022
posted October 13, 2010 04:34 PM
VERY good question.
We could burn more fuel........, oh, dirty dirty!!!!!!!!!
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 14, 2010 05:58 PM
try this
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4985552&showprevnext=1
or
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=5188992&showprevnext=1
2000redrocket
posted October 14, 2010 06:07 PM
wow scott the sism is real priceey.
the out put of a coil is a windings ratio primary to secondary.
but msd uses a much higher than the nominal charging system primary voltage.
and the math at sat 100vdc instead of 14 to 15 vdc is the gain also. i think some msd boxes run 400vdc to the primarys.
i was wondering if and will the ecu do it using the stock system. i would not want to find where to put that blue box if i could just put on stick coils.
unless the ecu can not handle grounding the greater load.
posted October 14, 2010 09:07 PM
i run an ARC-2 on my 12, dyno back to back tests, it gained some hp with it, 3-4??? (i forget).
I have one in a box for my Busa, will do tests with it pretty soon.
0.23251295089722 seconds processing time
