BIKELAND > FORUMS > ZX12R ZONE.com > Thread: muzzy advancer NEW TOPIC NEW POLL POST REPLY
biggmoinc
posted September 18, 2010 06:39 AM        Edited By: biggmoinc on 18 Sep 2010 14:45
muzzy advancer
quick question on installing the muzzy adjustable ignition advancer, mine has spun, n i dont remember which way to advance, do i rotate the outside clockwise the way the arrow on the ignition rotor is showing to advance. Right now i turned it so that the inside line is in between the stock line n the first line to the right of the stock line, but doing this looks like it would be retarding the timing versus advancing it since i spun the outside counter clockwise............UNLESS THE ROTOR SPINS COUNTERCLOCKWISE, then it makes perfect sense
biggmo@aol.com
tuusinii
posted September 18, 2010 11:12 AM
If I remember right it runs clockwise and that means to advance means turning the outer further clockwise. But to be sure is quite easy: raise your rearwheel up and turn the crank clockwise in gear and check that the rearwheel turns in the right direction.
biggmoinc
posted September 19, 2010 11:00 AM
Turned it clockwise, now the inside line is between the stock line n the first line to the left, went to bike week n ocean city, bike ran fine but when I cut it off it didn't want to turnover til the engine cooled off, once cooled off it fired up as usual n I went on my way, I'm bout tired of this bike, lol,
biggmo@aol.com
2000redrocket
posted September 22, 2010 05:07 PM
hi big. i just checked mine and as i thought it did not move at all.
(that was you who had theirs move correct?)
biggmoinc
posted September 23, 2010 05:50 AM
Yes sir, where's was ur inside line in relation to the outside stock line, now that its advanced (I think) its hard to turnover when engine is hot, it is a 1270 but didn't have this issue when advancer was retarded
biggmo@aol.com
posted September 24, 2010 08:20 AM
On any OHC engine, the crank rotates in the direction which pulls directly on the side of the cam chain opposite the tensioner. Be careful when you say clockwise or counterclockwise because they are both correct depending on which side of the engine you're looking at. I know we're talking about looking at the advancer on a 12 which is on the right (clockwise) side, but I'm just sayin.
FYI on the Muzzy advancer, each line is 5 deg. We most often recommended about 4 deg which is about a "1/2 a line" behind the first line from center going clockwise.
BrooklynNYZX12
posted September 24, 2010 04:58 PM
I used the Muzzy advancer in my '03 and adjusted it like DM mentioned above and it made a difference in the low rpm drivability of the bike.
Orient Express Top Street Bike Winner 8-4-07
posted September 24, 2010 05:39 PM
Brooklyn's 12 has a Muzzy with the advanced timing and my 12 has an Akrapovic without an advancer...I didnt notice any difference power wise between the 2 on the Dragstrip...
Im not sayin anything negative, just tellin what i notice...On the dyno im sure its a different story...
0.21352601051331 seconds processing time
