BIKELAND > FORUMS > ZX12R ZONE.com > Thread: tool steel arm and pullers NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted August 14, 2010 06:05 AM
anyone intrested in tool steel clutch puller parts?
we are making the long muzzy puller out of A2 and
i cut the arm (part the cable hooks into) off the shaft
that wares out for some due to stiff springs or too low
stack hight.
you will have to index and weld your arm on for the cable.
Stuart Racing
N.H.R.A . Dragracing.
posted August 14, 2010 09:36 AM
Seems like you should be making a puller(the one in the hub) out of tool steel....I never had prob.`s with the cable shaft one......
2000redrocket
posted August 14, 2010 10:14 AM
we not have a problem but the guys using stiff springs are the ones i was thinking about for replaceing the piece the cable goes to.
Stuart Racing
posted August 14, 2010 12:49 PM
Aaah yes......
NOX
PMRA / TMRC Super Street 4022
posted August 14, 2010 08:00 PM
if you are required not to run a lock up, I can see where this could be needed........
If not, as I have said, you are doing a bunch of crap wrong, unless you are still trying to use muzzy parts......
And by you, I mean everyone.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
2000redrocket
posted August 14, 2010 08:55 PM
well nox everyone i know who took thier "stock" zx12 apart i looked at the puller arm and there were big flat spots.i had to buy the muzzy tower piece. but it is the last one cause the next one i put in will be the A2 tool steel one we are making and i did not even brake one yet. just planning ahead. with a tool steel tower and a tool steel arm in a oil bath it should be the last setup needed.
if it works out making a stock length puller tower piece should be as easy.
i doubt as i said a couple of posts ago using 3 to 4 springs only the puler arm should be a non issue.
tuusinii
posted August 15, 2010 09:13 PM
If I understand right: some people using stiff springs are braking the part of the clutch puller that the cable connects? I've also had that problem in my first 12. After about 100k km (60k miles) when I was riding trough Europe late night on German autobahn I noticed that my clutch lever came to loose. I stopped and noticed that the part had gone in to two pieces because of the clutch cable. I then used couple of zipties to make it work, but it lasted only mayde 10 km and after that the puller rod itself broke. Rode to hotel without clutch and next morning went to an Opel (car) service where nice guy welded it together. Then rode 500km to the Italian Riviera where my wife would fly the day after and brought me an complete new clutch puller. So now I always have the welded part below the seat - just in case. But when examining the cable I found that the cable end had come rounded or in fact V-shaped during all the miles it had been on the bike (it was original part) and that probably broke the puller in the first place. So I changed the clutch cable and never had the same problem for the 20k km I sitll had that bike. So what I'm saying is that if You broke that part change also the clutch cable if it looks like worn.
posted August 15, 2010 09:32 PM
The "Clutch Nazi" has spoken!
2000redrocket
posted August 16, 2010 01:39 AM
the new one i put in from shnits is not a "kawasaki" part. i do not know if it is "harder" but is is somewat different in a good way to me.
hotmix
PIMP
posted August 16, 2010 04:19 AM
how much and do you have pics cause i am tired of having to buy new ones
NOX
posted August 16, 2010 06:28 AM
100,000 miles.............
yeah, time to look at wear and tear items like that........
LOL
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
2000redrocket
posted August 16, 2010 01:27 PM
did not get made yet. and hotmix which piece. i am not sure he will make the piece the cable goes into yet.do not know price on the longer piece for the lock up setup.
nox what do you mean? are you telling us we are f-ing up the part the cable goes into or the piece in the pressure plate.
2000redrocket
posted August 16, 2010 03:49 PM
just rockwelled the puller arm shaft. it rockwelled at 56. not worth making one.
NOX
posted August 16, 2010 04:48 PM
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.26230311393738 seconds processing time
