BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Help With Leaking Fuel Tank NEW TOPIC NEW POLL POST REPLY
WARBIRD
posted August 03, 2010 04:28 PM
Hey fella's..............I am working on a friends 03 ZX12 and it has a fuel leak from around the back plate where the sending unit is bolted. I replaced the gasket that goes between the back plate (up against the fuel tank ) and the top plate. I poured fuel in a little at a time with the tank propped up and it appears to be coming from between the back plate and fuel tank. Is this plate welded to the tank? There is no rust in the tank that I can see...........and the gasket is lined up properly. ( it will only line up all four holes ONE way. )
Any help or insight would be appreciated.........
Thanks,
Charles
I'd Rather Be Roadracing.
0.2208399772644 seconds processing time
