BIKELAND > FORUMS > ZX12R ZONE.com > Thread: game over for now NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted August 01, 2010 10:56 AM
game over for now
when tightening my clutch cover friday night it poped. come to look it over today and the case cracked at the bottom clutch cover alignment pin. leaking oil well now when the bike is off the stand. F>>>me.
posted August 01, 2010 10:59 AM
You mean the engine case cracked?
Stuart Racing
N.H.R.A . Dragracing.
posted August 01, 2010 11:12 AM
OMFG Dennis...So sorry to hear about that....Sometimes the cover gets cocked onto the locating pin and push`s down/up/sideways and could crack the case`s I guess...... Dammit man,you were almost there on the lockup tuning.....Maybe it can be welded????
Sorry brother......
tshultz
posted August 01, 2010 04:50 PM
wtf!!
2000redrocket
posted August 01, 2010 05:52 PM
i talked to someone i race with that works as a susike mechanic for 20 or so years and he said we can get it to stop leaking.
also talked to a friend that has a tig and i may clean it up and cook it to dry it and with the basket out he will see if he can melt it back together with out grinding. that will seal it up.
maybe tomorrow i will take a picture of it and post it.
i am so ready for my duster to get its engine.
2000redrocket
posted August 03, 2010 06:49 PM
here is the damage. it is not fatel but i am wanting to melt it back together with a tig before i contaminate it with epoxy and later decide it needs tiged. now to decide if it needs to be seperated from the engine or do it while together. i have a oil pan gasket so i can take the basket out and drain it and clean and bake the oil out. i may get away with it.
i just do not want to take it out and apart cause that will make me want to degree the cams and race cut the trannnnnny and put the 1270 kit in and sent the head to jim.
so you guys get the idea thet the timing is bad to have the engine out if i have to take the lower case half off.
posted August 03, 2010 06:55 PM
Doesn't look too bad to my untrained eyes. I am sure it can be done without taking the motor apart.
2000redrocket
posted August 03, 2010 07:03 PM
hardest part will be cleaning up a margin at the crack with no paint and no oil. i may sand it down by hand to controle the flakes.
i am going to use a valve spring pressure tool to get a handle on spring pressure for the clutch to make a good next move on static pressure.
Stuart Racing
posted August 04, 2010 05:37 AM
Good picture....Looks better than first explained.....Just burn out all the residual oil and v cut it so it gets good penetration.
posted August 04, 2010 09:11 AM        Edited By: VincentHill on 4 Aug 2010 17:12
Use a can of Good Brake cleaner and remove ALL of the oil, Geat with a Propane torch and clean again. then use a dremmel tool and clean the area about 1/2 inch on Both Sides and Behind after yopu remove everything , spray the Brake cleaner again THEN You may be ready to weld it!
You should post a warning because it Hurts to look at it!
shiphteey
posted August 04, 2010 12:13 PM
JB WELD FTW!!!!!
Gemini Motorcycles
2000redrocket
posted August 04, 2010 01:17 PM        Edited By: 2000redrocket on 4 Aug 2010 21:18
not my bike ship. !!!!!!!!!!!lol i have taken a 78 cb 750f with the chain in the engine and had plates welded in it and remated the halfs. this is a cake walk to that.
i just do not want to take the engine apart and have to dissapoint my self with it going back together stock. we will see. i am dissembling it today and get it looked at to see if i need to take the engine out. i will know by the weekend though i have a navy ship reunion saturday. maybe monday.
vince that is exactly what i was going to do. i love brake cleaner and torches and freezing parts.
2000redrocket
posted August 11, 2010 06:17 PM
back in the game
2fat2fly
posted August 12, 2010 12:16 PM
Nice job. It looks good.
Stuart Racing
posted August 12, 2010 02:48 PM
YEEEHAAAAW. Good job.......
aliveagain
posted August 12, 2010 03:48 PM
I had mine welded up with no problems although mine was apart.
2000redrocket
posted August 12, 2010 08:39 PM
i am going to buy a double shot of oil tomorrow morning and fill and flush and new filter and fill again. i may go to the track with a hand full of shims tomorrow night if no rain.
alive that looks sort of bad. where on the case was that?
aliveagain
posted August 14, 2010 05:52 AM
That is the very back that got in the way of the transmission gears bouncing around. You can see one of the shifting forks.
2000redrocket
posted August 14, 2010 06:01 AM
did not go friday night. bad looking weather.
0.23811912536621 seconds processing time
