BIKELAND > FORUMS > ZX12R ZONE.com > Thread: reed valve chamber block off plates NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted July 22, 2010 06:28 AM
wat are the for.. what do they do
http://www.muzzys.com/block-off_plates/index.html
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
Rock4173
posted July 22, 2010 07:56 AM
To remove the clean air system
posted July 22, 2010 12:04 PM
The don't do anything but block the fresh air passages to the exhaust port and look purty. You can block the passages with an aluminum plug or pipe plug and not use the plates just as well.
2000redrocket
posted July 22, 2010 06:26 PM
i smashed the reed supports flat and flipped them. though you should decide if you are doing the kleen air mod before you flatten the supports. i decided to try it and had to re arch the supports.
0.24024701118469 seconds processing time
