BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 03 ZX12R 50T sprocket who sells them, and would this be a correct setup? NEW TOPIC NEW POLL POST REPLY
dragbikercr
posted July 12, 2010 05:51 PM
Ive been looking for a 50 tooth sprocket for an 03 ZX12R. Anyone have one or know who sells them? I looked all over and the biggest I found was 48 tooth.
Im 230 suited 3"-9" swingarm extensions roughly 7" over, stock ZX12R strapped in front. Is this to much sprocket or doesnt anyone sell them this big? Looking to do a 17 front 50 rear... Any thoughts???
posted July 12, 2010 07:38 PM
Vortex makes them. you will be ok with that gearing, maybe even get a 51. should trap about the top of 5th. i was using 17 51 for awhile, then 17 50, now 17 49 but with a lower first trans gear. 190 suited
we have a sprocket specialists 56 on dads bike, but got it used, it may have been special order?...
SteveZX12r
posted July 14, 2010 09:15 AM        Edited By: SteveZX12r on 14 Jul 2010 17:17
If you check with Schnitz racing they sell the Vortex sprockets and they list up to a 52 tooth....
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=3279912&showprevnext=1
and I've always had pretty good service from them...
I personally run a very similar set-up, 17/50 gearing, and I'm about 230 suited.... I usually cross the line at around 11,000 rpm in 5th gear.....
2000redrocket
posted July 14, 2010 05:11 PM
i am geared 17/51 and you can even put the 16 on the front. but i must say in good air the 4.5 inch over i am at is not long enough for the 16/50 setup so hell no on the 16/51. i may try it at maplegrove while it is warm though. at cecil it wheelied a lot.
CJ
posted September 27, 2010 11:32 AM
i'm 148 lbs suited 16 48 sprockets bike is somewhat aggressive of the line problems with wheels does anyone think that maybe it might b wrong for my weight. 1.55 60ft. 9.36s et 147 mph
07 plasma blue zx14
Ain't no fun when the rabbits got the gun
posted September 28, 2010 12:25 PM
depends on wb, suspension, riding style ect ect....
CJ
posted September 28, 2010 04:44 PM
Mtc 1256 piston kit 14.7to1 cr ported head stock cams stock timing settings 63" wheel base ,stock suspension and launching at about 6000 rpms no lockup clutch when the light is green slam the throttle about three quarter of the way 119 mph 1/8th mile 147mph on 93 octane
07 plasma blue zx14
CJ
posted September 30, 2010 08:31 AM
does anybody have a good map for oxygenated fuel thanks in advance if anyone can help ferrellzx12@gmail.com tryin to keep the zx12 alive and not forgotten.
07 plasma blue zx14
posted October 02, 2010 12:35 PM
CJ, i weight 185 have 16-47 gearing on a 2002 61inch 12, lowered, Akrapovic, stock air filters-clutch-timing & NO Power Commander...Ran 9.35 & 152 on 87 octane pump gas...121 in the 1/8... temp was 80 degrees with low humidity...Yes stock motor never opened up...
I use to use mr9, just poured it in...I would get 124 in the 1/8 all day & 154 in the 1/4...
CJ
posted October 03, 2010 01:01 PM
Hey Crotchrocket whats your secret if u dont mind sharing beecause i never seen those those kinda numbers on my stock motor 116mph 1/8mile & 144 mph 1/4 mile please let me know i went wrong need help!!!
07 plasma blue zx14
posted October 03, 2010 03:28 PM
stock motor, K&Ns, PC3R, Muzzy stainless, pump gas
118-119 ,147-148
that was in 07, im about 190 suited. been playing with bigger motors since then
NOX
PMRA / TMRC Super Street 4022
posted October 03, 2010 04:56 PM
16 51 works good, except at sea level in good air, uses all 6 gears
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NOX
posted October 03, 2010 04:59 PM
Crotch Rocket is at stock wb, so I would think some of his top end, would come from less weight of turning some chain, etc, and he runs at a lot of sea levelish tracks......., i think....?
I have never busted 150, but my good map turns me 122 to 124 in the 1/8
I index race a ton now, so I am generally taking a bunch out of it.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 03, 2010 05:12 PM
The secret is not to drag the clutch & to lock the throttle ASAP...also to have a good tire on the rear, as in a new tire every 2 seasons even though it doesnt look wornout depending on how many passes you make in a season...If alot then a new tire every season...
By the way CJ, i had a 1.51 60ft. with the 9.35 i mentioned above...
Sounds to me your doin what you need to for your 12, i would put a 47 on your bike & launch a little higher RPM...maybe even a 46 since you have motor work...
You have to find the sweet spot...
posted October 03, 2010 05:19 PM
only 3 over NOX...61inches
Close to sea level...We lucky here in the North East...
My home track is RacewayPark-Englishtown, NJ & Maryland International Raceway-Mechanicsville, MD !!!
2000redrocket
posted October 03, 2010 05:21 PM
my 9.26 pass was with a 18/ 50 setup 1.54 60ft foot shifting clean. 121 in the 1/8 148 in the 1/4. but the air at MIR was extreamly good for that pass. like crotch rocket says mess with things and find what works for you. i bet we all have a small stack of sprockets by now.
just get a 16,17,19,44,49,50,51 and have fun.this is what i ended up with anyway. i my self have my bike a 4 speed and at 18/50 i trap at 11700.
2000redrocket
posted October 03, 2010 05:43 PM        Edited By: 2000redrocket on 4 Oct 2010 01:44
here is my best pass ever.
last weekend i had some weard mph going on. like first pass was 144.7 second pass was 149.27 same et to 2 hundreths. at 1900 AA not a real good air day.
NOX
posted October 03, 2010 06:59 PM
Man, thats big top end, for that slow of a 1000 ft time.
I wish I had time to test on a 1/4 mile more, and run my good map, that I run low 5.7s with.
Back to the guys bike here........
get your CHASIS set up before you waste a ton of time. LOW< LOW LOW, and set the suspension up. Get a coby adams pan, sidewinder, low pro tire, set it in the dirt with two inches of ground clearance, and you will be surprized how calm it will get.........
Even at short wb.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 04, 2010 05:03 AM
Nice Pass Red...
Very Very Nice Nox...
sami1
posted October 04, 2010 11:36 AM
What times with stock wheelbase?
We haven't many good condition tracks here in finland so we are riding normally at old airports. No need for (big) extends because the slippery.
posted October 04, 2010 12:24 PM        Edited By: KZScott on 4 Oct 2010 20:24
118-119 ,147-148
btw that was
17-51
7.5 over
2000redrocket
posted October 04, 2010 01:23 PM
9.62 with around a 1.62 60ft. stock length.
NOX
posted October 04, 2010 03:15 PM
My best was
1.401
3.728
5.722
122.2 mph
But, I now have a set up, that went
1.37
3.70
5.7.....something, cause I missed the damn 3-4 shift, and it went 5.74 at 114........LOL
I will get it better.......
I will post my new 9.50 set up times, after PMRA World Finals.........,
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
CJ
posted October 04, 2010 05:10 PM
Well sounds like all of u guys have found the sweet spot I will keep looking as soon i get the bike running again took it for ride Sunday afternoon bike shut down will not start FI code is 21 check the ohms on the crankshaft sensor checked out fine confusssssssed. I'm down here in the sunshine state sunny Florida where it always hot and humid maybe that why my numbers are down never had the bike on a dyno but you guys have me scratchin my head. JUST ONE HOME GROWN MECHANIC.
07 plasma blue zx14
sami1
posted October 07, 2010 09:06 AM
Nice shot.
Mine best 9,69 234km/h (145mph) with 1,64 60ft.
0.2676899433136 seconds processing time
