BIKELAND > FORUMS > ZX12R ZONE.com > Thread: cold starts NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted June 16, 2010 03:19 PM
cold starts
hey guys so every time i start my bike it never starts on the first try why is this? i have a 00 zx12 with fully muzzy's exhaust and k&n filters.... when i start is turns over and runs for just a second then when i restart it will either do it again or start up but run a little rough then level out any ideas about this????
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
biggmoinc
posted June 16, 2010 06:58 PM        Edited By: biggmoinc on 17 Jun 2010 02:59
This is normal, it takes a sec for the air box sensor n ecu to get the choke right for cold starts, the lever on ur left is only a fast idle n the bike will normally start n cut off, but then start an idle then pick up a fast idle, the Ecu will automatically cut the choke off When the temp sensor warms, now this info may b wrong but its what I've believed, lol
biggmo@aol.com
GOZR
GOZR
posted June 19, 2010 06:58 PM
Bobby same here no probs
-G
posted June 19, 2010 07:02 PM
Sounds lean. My Muzzy setup ran the same way without a power commander. It was fine with a power commander and good map, however.
spindian
i ride it like i stole it!
posted June 22, 2010 07:00 AM
try checkin ur battery... my 03 was doin the same, pulled the batt out it read 95% charged it and no problems since... so I figure 95% was too low a charge for my bike... also a power commander should help, runnin to rich will cause problems too.
0.23616003990173 seconds processing time
