BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Wego3 Tach adapter NEW TOPIC NEW POLL POST REPLY
SteveZX12r
posted June 10, 2010 03:57 PM
Wego3 Tach adapter
For those of you that have used the Wego 3 on your 12's, is the tach adapter required to be used on these bikes? or can you just wire it directly from the wego 3 to the black and orange coil wire on the 4th cylinder?
2000redrocket
posted June 12, 2010 12:18 PM
something tells me that you can not use a coil wire. i may have to look into it. i have mine on the factory tach wire going up to the tach. it has some spikes in the line but i am ok with it.
almost_les
posted June 12, 2010 07:29 PM
tap into a fuel injector. make sure its the wire that runs to the ecu and not the ground.
2000redrocket
posted June 12, 2010 08:37 PM
people have used the injector for the tach but the ecu totally drops the injector out at times. you will have places on trail throttle with no rpm trace.that in its self is not a big deal. but using the tach wire the ecu puts out is not a bad thing for me anyway either. some one used the cam sensor and had good luck with it also.
0.25943613052368 seconds processing time
