BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Top Speed Governor - When? NEW TOPIC NEW POLL POST REPLY
gsxrassassin
posted April 27, 2010 11:12 AM
Okay, so we all know the story, right? The Hayabusa came out in 1999 and then Kawasaki dropped the ZX-12R in 2000. The Europeans found out how fast these things were and brought an end to the top speed wars.
Q: Exactly when did Kawasaki start snipping the huge hairy ones from the ZX-12R? The common belief is it all started fresh with the 2001 production year but I've heard a few late 2000 models may have had their wings clipped too. Is there any way to tell (short of running my 12 to the top) whether or not my 2000 ZX-12R is snipped? Maybe some sort of VIN coding? Thanks.
GSXR
Over the hump, back up and running again!!
supra5677
posted April 27, 2010 03:16 PM
Wow my favorite subject. In my view and from the letter I received from Keith Parnell the zx12r was clipped in January of 2000. The ecu data provided by Ridge Racer shows an increased rev limi in the ram air compensation map to 12,350. Ignition timing and fuel maps are not optimal as Ridge Racer discovered after hacking the ecu. If you want more send me a pm
supra
posted April 27, 2010 03:22 PM
If you aren't going to run it to the top...what does it matter?
psycho1122
posted April 28, 2010 04:57 AM
Stock Y2K 12R power curve starts to fall off right around 10,500 rpm. "Just" enough power at 10,500 to "keep even with" the EyeAbusa. BUMMER.
Uncork the exhaust and fine tune it. The engine will make 25 more H.P. at 11,500 than stock. DONE.
ZXLNT
posted April 30, 2010 06:06 AM
At LEAST 25 more horsepower if not more...
suix
posted April 30, 2010 11:28 AM
99-00 busa doesnt have cat in their exhaust,as for zx12r that depends on countries/batch.
Thats the resonss why we have differents results in busa vs zx12r shoot out.
remember mach3?
gsxrassassin
posted May 01, 2010 12:35 PM
Wow, January 2000. That's crazy. Every now and then we do run the bikes flat out through 6th gear. It's definitely not unheard of with me and my buddies. Doesn't happen often - but does happen.
GSXR
orsancart
posted May 02, 2010 09:00 AM
out of curiosity has anyone taken the clocks (speedo)apart to see if there is plate that moves with the needle to pass through a detector this was normally done with the 400's its cheapest way of restricting speed ?????????????
thekaz
spell chequer is bustimicated
posted May 03, 2010 05:21 PM
the speedo was not the method of restriction. it was done via the speed sensor signal to the ecu. it can be derestricted via the bonniville box. the bonniville box will split the signal with one being unmodified sent to the speedo while teh other was modified to "trick" the computer into thinking the bike was going slower than it really was.
is this the best method ?? dunno
gsxrassassin
posted May 03, 2010 05:37 PM
Yeah, I heard of the Bonneville Box. It was Kawasaki's T.R.E., or something like that.
GSXR
psycho1122
posted May 04, 2010 05:06 AM
Bonneville Box is not needed on a 2000 model ZX12R.
No restriction. 2000 models received a more restirctive canister and a bit of tune in the ECU (High RPM).
0.25069403648376 seconds processing time
