BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2001 service manual NEW TOPIC NEW POLL POST REPLY
wby300
posted April 10, 2010 05:26 AM
2001 service manual
Anyone have a pdf of the 2001 zx-12 service manual? I have the 2000 but need the one for the 2001.
zx12haitian
:APB: BLACK MAN SPEEDING
posted May 02, 2010 12:33 PM
hmm i have to check if the one i have is for a 2001. ill get back to you
Your bike must be really fast b/c you were flying when i passed you
posted May 02, 2010 02:48 PM
its 99% the same
I have an 01, dad has the 00
what do you need to know?
wby300
posted May 02, 2010 04:43 PM
I need to know if the tach signal wire is pin 23 or 22 from the ecu, ridgeracer told me it is 22 and in the 2000 manual I have it says 23. I know there are differences in the programming in the ecu but is there also differences in what wires go where?
posted May 02, 2010 04:59 PM
the ecu wires are a little different, I know the tach signal wire on my 01 is a light blue coming out of the gauges, and I assume its the same colour at the ecu. I beileve you tap into it for the bonneville box. let me see if i can find the instructions...
wby300
posted May 03, 2010 07:19 AM
Well I have my ECU notched and I am wanting to hook up the wego3, I am going to use the blue comming from the guages for the tach wire, then I need to know what one of the 3 to use for the TPS for the other channel. I also need to know which wire on the TPS to use and the voltage for idle and full throttle, I think I can get the voltages by hooking to it and running the throttle with the key on. It has taken me almost a year to get everything to start tweaking the ECU and I still cant because I dont know what to hook where.
0.22656798362732 seconds processing time
