BIKELAND > FORUMS > ZX12R ZONE.com > Thread: SWFT QUESTIONS NEW TOPIC NEW POLL POST REPLY
Ballisticzx12r
& Deals Gap Board Member
posted December 06, 2002 01:39 PM
SWFT QUESTIONS
I am going to do the swing arm, can you tell me exactly what swing arm I should order... I understand there is a 7 and a 7r.
Also if the stock shock is acceptable, I just a got a penske and want to make sure it doesn't need to changed.
Thanks,
Bart
Be fast and Be safe
  Ignore this member    Click here to visit BallisticZX12R's homepage.
GOZR
GOZR
posted December 06, 2002 02:10 PM        Edited By: GOZR on 6 Dec 2002 19:55
Yea you right.
Ballisticzx12r
posted December 06, 2002 02:23 PM
Thank You Very Much...
I am know looking for a 99 ZX-7r swing arm, new.
Help anyone...
Bart
Be fast and Be safe
GOZR
GOZR
posted December 06, 2002 02:48 PM        Edited By: GOZR on 6 Dec 2002 19:56
That was for the twisties lover ..
DaveInDaytona
posted December 06, 2002 03:30 PM
I'll buy your old swingarm Bart.
DaytonaSportbikes Forum
posted December 06, 2002 06:23 PM
GOZR - I think you are talking out your but with regard to the strength of the two swingarms. Just because the 7R swingarm is bigger, doesn't make it stronger. The 12R swingarm was designed with a ton of internal bracing.
posted December 06, 2002 06:52 PM
who's going to be the first to post after they get "highsided" from this mod...lol
DaveInDaytona, shoot me an email: a750turbo@dragbike.com
DaveInDaytona
posted December 06, 2002 08:42 PM
And Kawasaki says this about the rear on the 2002, hopefully it's better....
"Kawasaki's patented UNI-TRAK¨ rear suspension uses a linkage system to progressively increase the damping and spring rate as the suspension is compressed. For better handling, the extruded-aluminum swingarm pivot was lowered, and the swingarm itself now uses an extruded-aluminum cross brace that was moved 2.5mm forward. The single shock is 5mm shorter than the previous version and has a softer spring. It also features a new stepless damping adjuster, which incorporates a check valve for improved damping performance."
Ballisticzx12r
posted December 07, 2002 06:13 AM
Dave,
I'll get it to you in May, now you will have to be at DGV.
Goxr, can I use a 2000 arm I can pick it up complete with caliper.
Thanks,
Bart
Be fast and Be safe
posted December 07, 2002 07:34 AM
Don't see why a 2000 arm wouldn't work, the design is the same.
GOZR
GOZR
posted December 07, 2002 07:39 AM
Same..
-G
EastBayDave
posted December 07, 2002 08:18 AM
why not have a welder throw a brace on a stock swingarm? cheaper right?
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
GOZR
GOZR
posted December 07, 2002 09:44 AM
got mine for 77 $ + suspension +plates and pivot
-G
Ballisticzx12r
posted December 07, 2002 11:51 AM
I order it found one complete, it is going to black or gray from what I understand. It will be a nice look with my new rims.
Be fast and Be safe
0.2389600276947 seconds processing time
