BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Anyone have 05 Manual? What's 3 long, 2 short flashes? NEW TOPIC NEW POLL POST REPLY
krexken
posted April 09, 2010 12:08 PM
I'm referring to the codes the computer flashes when you ground the wire in the tail of the bike. My 00 manual doens't show that 3 long flashes, 2 short ones even exists. Any help appreciated. Also would love to find a downloadable manual for an 05 if anyone knows where to look.
posted April 09, 2010 03:04 PM
something tells me it may have to do with the secondary throttle shafts. i have the 00 manual too...not in there
Texas12R
posted April 10, 2010 07:24 AM
11 Throttle sensor (ZX1200-B1/B2), main throttle sensor
(ZX1200-B3), malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or
short
13 Inlet air temperature sensor malfunction, wiring open
or short
14 Water temperature sensor malfunction, wiring open or
short
15 Atmospheric pressure sensor malfunction, wiring open
or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or
short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor, malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
41 Injector #1 malfunction, wiring open or short
42 Injector #2 malfunction, wiring open or short
43 Injector #3 malfunction, wiring open or short
44 Injector #4 malfunction, wiring open or short
45 Fuel pump relay wiring open
46 Fuel pump relay stuck ON
51 Ignition coil #1 malfunction, wiring open or short
52 Ignition coil #2 malfunction, wiring open or short
53 Ignition coil #3 malfunction, wiring open or short
54 Ignition coil #4 malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Anyone have 05 Manual? What\'s 3 long, 2 short flashes? NEW TOPIC NEW POLL POST REPLY
0.23205900192261 seconds processing time
