BIKELAND > FORUMS > ZX12R ZONE.com > Thread: IS THERE ANYWAY TO TRICK THE MAP SENSOR NEW TOPIC NEW POLL POST REPLY
supra5677
posted April 08, 2010 02:34 PM
I know in a car you can make the maf sensor think the engine is getting more air than it
actually is. Is this possible to do with our zx12r?
supra
smokeysevin
ZX12r-STX15f hybrid motor
posted April 08, 2010 08:14 PM
same thing, just get a signal calibrator, i run one of these on my truck, might be a little big for a bike though
http://www.urdusa.com/product_info.php?cPath=66_72&products_id=1260198051&osCsid=s8a9aobi9usu9v7nfdfvj32391
all it does is take a reading from rpm and tps and it uses that to alter the signal (maf in this case) but you could use it on a map sensor as long as it runs on the same voltage
Sean
1498 cc
69.2mm stroke
83mm bore
JOHNJ
posted April 09, 2010 09:22 AM
EBAY sells some of those gimmick wire in trick sensor parts....
Look around there. Sure you`ll find something like what you`re talking about.
JJ
posted April 09, 2010 06:17 PM
im sure adding resistance to the circuit would do something
2000redrocket
posted April 16, 2010 11:59 AM        Edited By: 2000redrocket on 16 Apr 2010 19:59
mr supra the differences on the voltages the ecu gets to switch from one density colum to a nother is not the same accross the board on our zx12 ecu. there is bigger jumps around the higher vacume areas and as it gets twards 75cmhg it gets smaller jumps in vacume to get to a nother colum. it should help a certain area but hurt others as the jump may be off.
with a pipe we have to lean out the low end of the rpms a lot then ritchen them up around 3000 and then lean it out some then ritchen it up.
0.24106502532959 seconds processing time
