Bobbydigital17420
posted March 17, 2010 08:12 AM
zx12r spark plug removal
hey guys good weather is gettin closer everyday, and im tryin to finnish my 2000 zx12r. i need to replace the valve cover gasket. i have started to remove the stuff from above the cover and first off i cant get the pastic cover off any tricks for this....second i have all the coils loose from the plugs but i can only fully remove one of the the of one the left side.. is this normal any tricks for this????
any help would be great need to get this done so i can go out on these nice days
tuusinii
posted March 17, 2010 11:57 PM
They're a little bit tight but You can turn them out only in one direction. They turn out to mayge clock position 9:30 or 2:30 depending whether it is #2 or #3 plug. The rubber will give You just enough space to do it.
NINJA12
posted March 18, 2010 11:30 AM
yes gently turn and pull the coils until the come out.
use the spark plug tool in the kit when you get to the plugs.
It's the only way to fly!
Emtsuj
posted March 28, 2010 06:09 PM
You can use a wiggle joint just above the spark plug socket and a short 4" extension. I changed mine while I had the throttle bodies off. It is much easier that way. You have to wiggle the coils as you pull them until you find the right angle. After you do it once, it is a quick job. As tuusinii said, turn them in the right direction and the rubber will give enough to get them out.
