BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Shift Light installation NEW TOPIC NEW POLL POST REPLY
jse20
posted November 14, 2002 04:24 AM
Hey, I got my shift light. Exactly 3 days after PayPal locked his account. Talk about great customer service!
Anyway, I am looking for installation advice. I have read the tach wire on the instrument cluster does not work correctly and that the Harlan Shift light needs to be connected to the stick coil. Can anyone who has installed one of these give me some installation assistance? How exactly should this be wired?
thanks
  Ignore this member    Click here to send jse20 an ICQ message. Click here to add 1 to your ICQ list.
DJONES
posted November 14, 2002 06:33 AM
The tach wire off the instrument wire worked fine for me.
DJ
DJ JONES
Persimmion Red ZX-12R
Humble, Texas
http://www.texas-offroad.com
  Ignore this member    Click here to visit djones's homepage. Click here to send djones an AIM message.
jason370
posted November 15, 2002 01:45 AM
might a non drag racer want a shift light?
'02 ZX12 black/gold
  Ignore this member    Click here to send jason370 an AIM message.
your car is slow
Fuck Nitrous...Got Boost?
posted November 15, 2002 06:37 AM
What wire is it by the way? I just got my light too
Do not taunt happy fun ball!
your car is slow
posted November 15, 2002 10:58 AM
Aight none of ya post whorin bastages knows which wire it is?
Now I gotta break out the fookin manual :/
moonzx12
posted November 15, 2002 11:06 AM
it is the light blue wire going in to the speedo panel. i think it s the upper left. it is on the end for sure
your car is slow
posted November 15, 2002 11:12 AM
ty
jse20
posted November 15, 2002 05:23 PM
I am going to install mine tonight. I just got back from the Gap the other day. Had a great time, one guy ended up in the hospital but made it home ok. Broken scapula and clavicle, a little bleeding in the brain. His bike is still ridable so it wasn't too bad of a day.
posted November 15, 2002 05:24 PM
Wow, was he riding with the brain bleed?
jse20
posted November 15, 2002 07:05 PM        Edited By: jse20 on 15 Nov 2002 19:05
No, he wont be riding for awhile, he was hospitalized Sat. The bleeding had stopped by Monday and he checked out of the hospital on tuesday against doctors wishes. This friggin shift light does not work on the tach wire. I will probably wire it down to the coil tomorrow or Sunday. So, uh... which side is number one? I would guess the right or clutch side. yea?
jse20
posted November 18, 2002 07:58 PM
IF the birds egg blue tach wire does not trigger your shift light where do you connect it? Where is the number one stick coil? Anyone done this that can help me out?
thanks
your car is slow
posted November 19, 2002 09:18 AM
Sure you got the tap on right? It shoudl work fine if you got hte right wire.
The stick coil for each cyl is up under the airbox
jse20
posted November 24, 2002 08:06 PM
YCIS
Looked at the wiring today. Tested the connection and it was good. Light blue on the upper left as you face the front of the bike and the rear of the cluster. The light would not trigger. I moved it to the ground on the number one coil thing, reprogrammed it and it works perfectly.
THe number one cyl is on the left side as you sit on the bike.
Next project is probably the dry nitrous kit. I think I will ask fot that as my christmas gift.
Your Car Is Slow
posted November 24, 2002 08:47 PM
perhaps we have the wrong wire...*shrug
Ill go look it up in the manual to make sure.
krexken
posted November 25, 2002 08:45 AM
Some ignition devices like the Dyna can use the light blue wire for triggering, not an MSD or anything that needs a ground signal for triggering.
posted November 25, 2002 04:12 PM
exactly the dyna uses the light blue wire,
MM
0.23577189445496 seconds processing time
