BIKELAND > FORUMS > ZX12R ZONE.com > Thread: muzzy ign.advancer install? NEW TOPIC NEW POLL POST REPLY
mach111
posted November 12, 2002 11:11 PM
I need some help installing the advancer from muzzy's.is there anything special i should do?bike is stock with pipe and filters.what timimg is a good starter not over 5deg.?
i've had the cover off but want to make sure its set right.
ZXtra
posted November 13, 2002 01:32 AM
mach...Don't advance it any more than a couple degrees to start. It is better to have too little timing than too much.
Too little timing will result in a slight power loss. Too much timing can result in detonation and maybe a broken ring or a hole in a piston (and a BIG power loss).
Mine ran best at 5 degrees advanced, so I set it at 4 degrees advanced to be safe.
Best way to set it is on a dyno. -ZXtra
fastestr1
posted November 14, 2002 10:43 AM
The most important thing to do is us lock tight. I am spot welding mine on so I dont burn up another motor on NOS.
Black 02, 8.99 @ 161.95 motor on NOS
Put one knee down for the curves and both knees down for GOD
jason370
posted November 15, 2002 01:39 AM
maybe i need one
'02 ZX12 black/gold
  Ignore this member    Click here to send jason370 an AIM message.
justoyz2
Justoyz Racing
posted November 15, 2002 10:58 AM
well spoken Fastestr1....Now, let's think about a new name. It's good to see kids grow up to become Men......R1=kid / zx12=Man
posted November 15, 2002 12:00 PM
Yah, definately use loc tite!
fastestr1
posted November 15, 2002 04:50 PM
Yes, I am becoming a man thanks to mentors like you. And the R1 is stolen and gone so a new name is in order, now for a name? ????
mach111
posted November 16, 2002 01:15 AM
zxtra,is your 5 deg.advance on a stock bike with just pipe and p.c?i went 2.5 and cant tell a bit of difference.this timing and electronic stuff like bike sensors ,computers always had me at a loss,what is the stock setting?is going 2.5 meaning 2.5 degrees more than stock?my bike seems to not pull as hard as it did,its not too bad,but noticable at 2.5.which way should i go now?theres no other symptoms,but a little loss in pull.
ZXtra
posted November 16, 2002 11:02 PM
mach...My 12 is even stocker than that! Factory exhaust (slight mods), no P.C., K+N's, no kleen air, heat blanket, red paint, 166 H.P.
Did you rotate the outside ring on the advancer clockwise to advance? Each mark is 5 degrees.
When I installed mine I noticed better throttle response and believe it or not better gas mileage.
It really is better to get it set on a dyno. I picked up 2.8 H.P. but results among the members has varied. Some even say theirs ran best at the stock 0 setting. The dyno will tell you. -ZXtra
IslandRider
posted November 16, 2002 11:12 PM        Edited By: IslandRider on 16 Nov 2002 23:13
fastestr1.....how about "Driven" since you won't stop until you set the track record for non-wheelie bared bike :-)
When are you giving me the advancer to weld???
fastestr1
posted November 16, 2002 11:26 PM        Edited By: fastestr1 on 16 Nov 2002 23:38
Tomorrow is a good day how about for you? And you are right about the track record, but I want us the go to a 60" wheel base class. So it is more rider and not just who has the money. I also saw my RC 1/10 scale nitro rail car can't wait to race it in Jan 03. As for the name driven is a good start.
mach111
posted November 17, 2002 11:44 AM
mine definatly runs better at the stock ign.adv.
beansbaxter
posted November 18, 2002 10:55 AM
For what kind of riding do you need one of these?
your car is slow
Fuck Nitrous...Got Boost?
posted November 18, 2002 10:56 AM
My advancer set at 2.5deg cured that low stumble around 2.5 - 3k
Do not taunt happy fun ball!
beansbaxter
posted November 18, 2002 10:57 AM
So it smooths out those low spots in the powerband?
JoshDunn
posted November 24, 2002 01:53 PM
If you have a pciiir then you don't need the advancer right? Maybe it would be worth installing an advancer only and leaving the stock map? Cheaper. I'm just looking for cheap horsepower.
Yosh Tri-Oval, PCIIIUSB Tuned by Nels
fastestr1
posted November 24, 2002 08:55 PM
With all the problems people are having with the pc3r it might be better.
zxlnt
posted November 25, 2002 06:44 AM
If u want cheap, then just do what lots of people did before the advancers came out. Slot the pickup coil and slide it to advance the timing that way. I ran mine for a long time that way with nary a problem.
0.22729897499084 seconds processing time
