BIKELAND > FORUMS > ZX12R ZONE.com > Thread: what to do at 20,000miles NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted November 18, 2009 09:23 PM
hello the weather is gettin cold so i think im goin to take my bike off the road and start lookin into what i should do for maintence at the 20k mile mark. i git the bike with 13k and have had no problems what so ever(knock on wood)..... the only thing that i can tell i need to do for sure is a valve cover gasket, what else can be done while i have it at this stage of being apart???
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
check lash
Bobbydigital17420
posted November 18, 2009 09:30 PM
what is "lash"??? and ho wwould you check said :lash"
posted November 18, 2009 09:44 PM        Edited By: KZScott on 19 Nov 2009 05:44
valve lash(clearance). feeler gauges
woppi
posted November 18, 2009 11:11 PM
which year do you have ?
1st TFA Member / Austria !
2000 Limited ZX12R NOS
tuusinii
posted November 19, 2009 12:06 AM
Try first the cam position sensor gasket if the leak looks like coming from front left cover of Your cam cover casket. It usually is the cam position sensor and not the cam cover casket. At 20k change the engine oil + filter, clean air filters, check valve clearances, grease rear suspension joints, change front fork oils. And if not done change the brakefluids. Also checking throttle body sync and TPS-position would be wise. Plus all other normal wear items (tires, brake bads)
psycho1122
posted November 19, 2009 05:22 AM
If you are really ambitious..... Drop the oil pan, check and clean the screen. Then pull the oil pump rotor, inspect for knicks and replace if nessessary. Use some Lithium grease on the lobes when re-installing the rotor.
Bobbydigital17420
posted November 19, 2009 07:19 AM
i ride a 2000 zx12r and at a closer look it doea appear that the leak is coming from the cam position sensor how do you check throttle body sync and TPS-position
twista
" Get up, and Stay up ! "
posted November 19, 2009 03:53 PM
TPS with a multimeter,, 1.084-1.086 is the spec,, but im hearing that 1.16 is a hot setup,, waiting on an answer for that ...
0.29295706748962 seconds processing time
