BIKELAND > FORUMS > ZX12R ZONE.com > Thread: problems NEW TOPIC NEW POLL POST REPLY
johnzx12
posted November 16, 2009 12:42 PM
problems
what would cause brand new rebuilt engine not to have oil pressure
posted November 16, 2009 01:52 PM
missing the gear on the back of the clutch basket or maybe installed backwards. missing a piece in the pump...
aliveagain
posted November 16, 2009 03:24 PM
Not primed. I came up with a gadget that spins the sprocket in back of the basket to make sure the pump picked up a suction.then I'll put the clutch in and start.You can try prefilling the oil filter.
posted November 16, 2009 04:41 PM
if its an air lock prefilling the filter should do it.
theres a plug on the left side of the bike just behind #1 throttle body. unplug it and the injectors wont fire. you can crank it over with the starter to build oil pressure with no fancy tools and it only takes 5 seconds
on a fresh build i like to grease the pump rotor and gob in a bunch of assembly lube. a nice mix hasnt failed yet. oil light goes right out after its fired up
rquinn
posted November 16, 2009 04:47 PM
Dam!!! John give me a call bro.
RON QUINN
almost_les
posted November 16, 2009 05:19 PM
try loosening up the oil filer until there is a small gap between it and the engine. this will vent out all the backpressure and let the pump get primed. as soon as you get oil coming up, stop, tighten it, and hook up your ignition/fuel injection. i did this when i rebuilt my motor and the oil light went out right away after firing it up. i use this same method for oil changes too.
like scott was saying, make sure the oil pump did not go in dry. and dont pack it with thick grease either. just a nice healthy coating like butter on toast will get the job done.
johnzx12
posted November 16, 2009 05:24 PM
thanks for u guys input my builder call me an said he figured it out
johnzx12
posted November 16, 2009 05:30 PM
ron what up- this bike havent did nothing but cost me a lots of money an headache that was the best news i heard all day
2000redrocket
posted November 16, 2009 05:40 PM
if the neg crank case mod in on the bike tale off the oil fill cap and start it.
0.30052399635315 seconds processing time
