BIKELAND > FORUMS > ZX12R ZONE.com > Thread: PCV wit auto tune NEW TOPIC NEW POLL POST REPLY
biggmoinc
posted November 15, 2009 07:57 AM
PCV wit auto tune
Kinda sucks not having this option for my nearly decade old 12r. Does anyone think this is better than the wego setup
biggmo@aol.com
Marcelo
posted November 16, 2009 12:06 PM
Big difference is the PC5 will adjust air/fuel ratio on-the-fly, and continually adjust in real-time for changing conditions. The WEGO III/IV is a datalogger, so you must edit your PCIII fuel table after downloading the data. If a PC5 was available for the 12, I would prefer it over a Wego. JMVHO.
2001 ZX-12R w/ Akrapovic Evo, PCIII USB, Ignition Module, Quick Shifter, BMC Race Filters, Ivan's Kleen Delete Kit, Racetech Goldvalve/Springs, Scotts Damper, Goodridge SS Lines, Pazzo Levers, Corbin Seat, Helibars G2, Throttle Meister, Double Z Quick Throttle, GIPRO X Type.
biggmoinc
posted November 16, 2009 05:11 PM
who gonna hack this pc5 for me n cut n splice sum wires so it can work on my bike, lol
biggmo@aol.com
kaw12
posted November 16, 2009 07:24 PM        Edited By: kaw12 on 17 Nov 2009 03:27
hey im with you, i know a guy who retrofitted his gxxr1k 07 with the 09 pc5. so i know it can be done. i got off the phone with dynojet and they say retrofitting the early bikes from 09 was going to be a long time as they are still working on the 09model.
biggmoinc
posted November 22, 2009 05:24 AM        Edited By: biggmoinc on 22 Nov 2009 13:25
It should work on ne fuel injected bike i would think, it may not plug n play but each wire should go to the same thing as an 09, what could be the difference, as long as u know what wire goes to what, TPS, REV, O2 SENSOR, INJECTORS, HOT n GRD, dont know if it would have an acc wire or not, I'm sure if they can hack an ECU they can do a PCV, lol
biggmo@aol.com
0.25990319252014 seconds processing time
