BIKELAND > FORUMS > ZX12R ZONE.com > Thread: help NEW TOPIC NEW POLL POST REPLY
cltch
posted November 06, 2009 05:37 PM
help
my clutch is starting to go!!! just ondering if someone could give me some details in do it.and is it a pain in the ass?
also i think 1st gear is also going. in 1st it chugs and sounds pretty bad. anyone have any ideas?
DeathProof
deceased
posted November 07, 2009 02:05 AM
easy job, just buy an oem/ebc kit off ebay and soak the friction plates in oil while you disasemble. you just remove the cable, then cover, do not disassemble the puller rod that is built into the cover but remove the guard and rubber damper, inspect puller seal for wear/leaks and clean/lube bearings with oil. remove the 6 bolts and springs from the pressure plate. pull out the old clutch pack, inspect the solid steel plates for burns or warps, if good clean with brake cleaner and reuse. some kit come with new steels so read all directions carefully. read twice, install once. reassembly is by the book. GUYS!!!!!! get all ur manuals IN PDF here for free. check it.
http://www.carlsalter.com/motorcycle-manuals.asp
posted November 07, 2009 09:35 AM
buy only oem
http://www.bikeland.org/board/viewthread.php?FID=1&TID=49121&set_time=1257615227
more details on the "chugging"??
cltch
posted November 09, 2009 04:00 PM
buy only oem
its hard to explain....
if i stay in 1st past 10mph it will jerk and catch the gear hard. and i can not ride in 1st past 10mph,if i do go past it,it will slip and grab bad
0.22169995307922 seconds processing time
