BIKELAND > FORUMS > ZX12R ZONE.com > Thread: not shifting right NEW TOPIC NEW POLL POST REPLY
aliveagain
posted October 20, 2009 03:15 PM
not shifting right
I put the engine back together and started it for the first time since changing transmission.I get no neutral light and the bike will not spin the tire when the shifter has been kicked down all the way.It's like the bike is in neutral when it should be in first.I know the 3 bb's were installed when I put 5th gear on.I am stumped on this one.
posted October 20, 2009 07:15 PM
was it "in neutral" when the cases were put together?
aliveagain
posted October 21, 2009 04:18 AM
Don't know. I think the neutral indicater was upside down when installed and I'll have to look more closely at any pics in the manual.I did pull the clutch cover to have a look see and found the lock-up carrier bearing had popped out of the cover.I don't know if that may have been the cause.
aliveagain
posted October 22, 2009 03:57 AM
fun pulling the shifting drum out while motor is still in the frame.I love it when oil drips down on your face and glasses.Lady bugs were out in force last night so constant cleaning out of them flying critters slowed me down.
Stuart Racing
N.H.R.A . Dragracing.
posted October 23, 2009 05:34 PM
Any progress yet.....
Mine did that too when I put the new trans. in....It was just the extended spacer on the shift pawl down by the clutch basket, too short....Allowed the pawl to slide over away from the mechanism.....
aliveagain
posted October 23, 2009 07:23 PM
By looking at the gear position switch,I think I was off by 180* and was actually reverse shifting.I pulled the bottom two shifter forks and the drum while in the bike and it seems like it is ok now however I haven't gone through the gears yet.I started it just to do a heat cycle and burp the radiator but it won't idle right.Codes are being sent out as the throttle position sensor and the airbox pressure sensor along with the gear selector switch.I didn't reverse the two common connectors and they check out electrically,so I want to check the ground.good news is the neutral light works now.
NOX
PMRA / TMRC Super Street 4022
posted October 25, 2009 08:18 PM
When you get a RnD tranny, you dang near cant get it into neutral.
I love it.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
aliveagain
posted October 27, 2009 03:53 AM
After a couple of rides,I noticed I need to use the clutch to shift it into sixth.
0.26509499549866 seconds processing time
