BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 1270 bore kit NEW TOPIC NEW POLL POST REPLY
Streetstretch
posted August 25, 2009 08:12 AM
1270 bore kit
I have a 2000 kawasaki zx-12r and im looking into the 1270 kit, just wondering if anyone has an idea bout how much it would cost to get the kit and have it installed
almost_les
posted August 25, 2009 08:45 AM        Edited By: almost_les on 25 Aug 2009 16:46
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=789946&showprevnext=1
buy the tools and put it in yourself. its a really simple job. you just pop off the head and cylinder and throw on the new stuff. id spring for adjustable cam sprockets too. no point in running stock cam lobe centers on a bigger higher compreession motor. also you can keep your ptv in check with them. win-win situation
Streetstretch
posted August 25, 2009 01:43 PM
what are some good brands of the 1270 bore kits
almost_les
posted August 25, 2009 05:50 PM        Edited By: almost_les on 26 Aug 2009 01:54
muzzy is the only one that makes a "kit" with everything. it uses wiseco pistons. is far as i know wiseco is the only off-the-shelf 1270 piston. when bought separately you still need to buy the head gasket, base gasket, and send you block off to get bored out and replated.
posted August 25, 2009 07:20 PM
Muzzy uses JEs, its actually a 1266cc kit or something like that if you want to get technical
Wiseco makes a 1272cc piston set
JE also makes a 1287cc piston set (commonly refered to as a 1290) APE offers an exhange program with this one as a kit
Streetstretch
posted August 26, 2009 02:34 AM
Do you have websites for all those kits
woppi
posted August 26, 2009 03:40 AM
i have a new 1272ccm wiseco piston kit + damaged stock cylinder --- 4sale !!!
my email: woppi@drag-race.at
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
woppi
posted August 26, 2009 03:43 AM
http://zxzone.com/pistons.html
http://www.muzzys.com/ZX1270-S/index.html
woppi
almost_les
posted August 27, 2009 08:32 AM        Edited By: almost_les on 27 Aug 2009 18:15
here are the results from doing the math based off the muzzy site:
muzzy says its a 2.5mm overbore in the "1270cc kit", making it an actual 1272.3
the "1375cc kit" uses a 2.4mm overbore and 60mm stroke crank making and actual 1374.7
but they say that the stroker crank will take the 1270 kit to a 1375. that actually makes a 1378cc motor
but, if you really wanna go fast, talk to ace performance about doing a 1287cc motor.
posted August 27, 2009 06:20 PM
muzzys 1270 is a 2.4mm overbore not 2.5. if you read 2.5 on their site its a typo. the 1375 is the same piston kit only with a 4.6mm stroker crank.
Megabyte
posted August 27, 2009 08:21 PM
This is a little off topic, and probably a dumb question, but how accurately can you measure your cc's w/o opening up the engine?
posted August 28, 2009 06:36 PM
im not sure how you would check bore diameter without popping the head off to fit in a bore gauge....
Megabyte
posted August 29, 2009 02:27 PM
That's what I was thinking, but was wondering if someone might have figured out something..
Thanks,
0.2458701133728 seconds processing time
