BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Motorcycle Jack Advice on Swingarm Swap NEW TOPIC NEW POLL POST REPLY
Dustman1
posted August 12, 2009 10:05 AM
Hi Guys,
I am a newbie here so hope you all can help me out.
Going to swap out my swingarm this weekend to a new stock one, current one has the paint peeling off of it at the weld seams.
What do you recommend to support or jack the bike when trying to do this since you cant use a pitbull in this procedure? The manual shows like a scissors type jack but is that safe and where do you place it for the best stability? Or if anone has something better to use.
How much trouble or any caveats in doing this swap that you guys have heard of or run in too when swapping out the swingarm. I have a current shop manual to assist me.
What size is the pivot bolt hex hed?
Almost forgot the bike is a 2003 ZX-12R
Thanks for all your help,
Jeff
BALTIMORE410
posted August 12, 2009 02:40 PM
you gonna need three people.... two bricks and a long pole that can go through the holes where the swing arm bolts up to...... if u need help let me know i can wlk you thru it piece by piece
  Ignore this member    Click here to visit BALTIMORE410's homepage.
posted August 12, 2009 03:00 PM
i hang the subframe from a rafter in the garage. with ratchet straps you dont even need a jack
0.43840885162354 seconds processing time
