BIKELAND > FORUMS > ZX12R ZONE.com > Thread: how do you know if your stack hieght is off? NEW TOPIC NEW POLL POST REPLY
Chango
posted August 09, 2009 11:29 PM
I just had my clutch done. The clutch still seems a little off. If I slowly engage the clutch the bike will shake quite a bit. I also noticed that when I rev the motor with the clutch fully engaged the bike will still try to pull a little! Is this right? If not what do you suggest? thanks !
tuusinii
posted August 10, 2009 02:01 AM
Did You clean the fibers and steels good from the grease they're when You got them? Use some brake cleaner or equivalent the get them clean. Mine also became "shakey" when I wasn't carfull in cleaning. Little bit of drag is normal especially when oil/engine if cold, but You shouldn't notice it if Your on the bike but when rear wheel is of the ground it will spin a little... Did You put the first smaller fiber and the rattle rings inside?
posted August 10, 2009 06:41 AM
All that is normal.....
posted August 10, 2009 11:55 AM
you know by measuring it, or by the angle of the puller if its in good shape, its all in the manual
Chango
posted August 10, 2009 10:57 PM
Man I should have been clear. I have no mechanical skills. My mechanic is the one who did the clutch. I hate to say it but I don't have the tools or know how to put in a clutch. I just noticed the clutch seem to vibrate when hooking up! I will forward him the questions you guys offered and see what he says. Thanks!
NOX
PMRA / TMRC Super Street 4022
posted August 11, 2009 06:55 AM
8 mm socket, and a allen wrench are all that are needed to change the clutch out......., oh, and a screwdriver if you dont have the fairing cut around the clutch cover like some of use do........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted August 11, 2009 12:08 PM
there are step by step instructions in the section of the manual i posted in a new thread. its really not that bad, just dont put the steels in backwards
0.22168922424316 seconds processing time
