BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ZX12R cam timing NEW TOPIC NEW POLL POST REPLY
chavcat
posted August 02, 2009 10:34 AM
ZX12R cam timing
Can cam timing be checked/adjusted with the motor in the frame?
blueshark
posted August 08, 2009 11:07 AM
Yes you can, it helps to remove the ram air tube to get to the exhaust side. If you ever pull the cams to adjusts the valves, drill you some holes in the cam cap to get a straighter shot to the outside buckets of the number #1 cyclinder.
chavcat
posted August 08, 2009 09:06 PM
Thanks for the tip!
posted August 09, 2009 07:17 AM
just cut the end right off
chavcat
posted August 09, 2009 03:04 PM
Scott - that is the simplest clearly. Great photo.
Thanks!
posted August 09, 2009 07:13 PM
np, got the idea from Karl
0.2236180305481 seconds processing time
