gerso
posted June 22, 2009 07:30 PM
High-altitude ECU
Did a longer ride recently at lower altitude with a stock 2000 bike with Kawasaki's high altitude ECU, and fuel economy was pretty crappy, much crappier than the 40 mpg I got one time holding a steady 100 mph at high altitude in CO.
What do you guys know about this ECU? Should I try to find a regular one? Does it make a difference?
I have always been bothered to think I couldn't use anyone's map if I were to get a PC3.
If I were to do an exhaust replacement from stock, what will keep the stock torque levels on the lower end of the RPM range, be as quiet as a used stock system, and make it a worthwhile upgrade along with the PC3?
Mileage counts because I'm always running out of fuel at the worst times, and it's hard to make good time on a trip if I'm always stopping to keep my tank at least half-full.
Recommendations and offers are both welcome.
