BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ZX-12 High Flow Fuel Pump with 1270 kit NEW TOPIC NEW POLL POST REPLY
02zedx12r
posted November 09, 2001 06:26 PM
Is the h/f fuel pump a must if you have the 1270 kit installed, and how much of a difference is the MPG.
Live to Ride
posted November 09, 2001 06:32 PM
It is not "a must". It gives you a cushion. Your stock pump is at it's upper limit at 200hp. The higher flow pump operates in a more normal range. Mapping (and your right hand) controls mpg, not fuel pressure. You need to re map or lean out your system about 3% after installing the pump.
Doug
02zedx12r
posted November 09, 2001 06:43 PM
Doug
Thanks for the help.
Live to Ride
cliffrandall
posted November 09, 2001 07:46 PM
Hi guys......If I might add my 2 cents worth, the Muzzy high flow pump smoothed out my motor quite noticably in the low to mid range. I do not know why, but it did, and for that I'm thankful.
Cheers,
Cliff
posted November 10, 2001 10:06 PM
I'm going to put mine on tomorrow. I put one on the 1361 bike, but the 1270 bike has suffered along with the stock pump this whole time. BTW, haven't dyno'd it after adding the CF ram air, but it was making 196hp before...
posted November 13, 2001 08:29 AM
Put the H/F pump on last sunday night. The weather has been majorly crappy up here in the PNW, so don't even want to wheel the bike out to take it to the shop to dyno it and remap for the big pump.
NINJA12
posted November 13, 2001 11:34 AM
Where does the muzzy pump mount?
Inside the tank like stoker, or
external? Do you completely remove or
somehow bypass the stock.
Thanks.
posted November 13, 2001 11:53 AM
Thanks.
inside the tank, it replaces the stocker
NINJA12
posted November 13, 2001 12:13 PM
Thanks.
0.21359896659851 seconds processing time
