BIKELAND > FORUMS > ZX12R ZONE.com > Thread: motor is broken in.....suspension set up NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted April 27, 2009 05:00 PM
excuse my french but.........OW MY F***ING GOD AFTER ALL THE B.S. I WENT THRU WITH DDE THAT BUILT M MOTOR I AM DEFFINITELY SATIFIED WITH THE RESULTS!!! power is everywhere but i feel a huge surge fom 3700 rpm all the way up to 7rpm but from 7 to redline it seems like it pulls even harder.....compared to the red zx12r i own this thing is a monster only problems im having now is from about 140 to 180 the front tire shakes hard real hard was wondering what kind of tuning could i do to the suspension to make it more stable....... my other bike i can get up to those speeds and feels like a caddilac ((maybe because the swing arm is stretched???)) not sure
the thought of having nitrous on top of this....this thing almost just aaaaalmost maakes me wanna say 2 much.......at least for now maaaaan ow maaaaan
  Ignore this member    Click here to visit BALTIMORE410's homepage.
posted April 27, 2009 05:39 PM
steering damper? raise the front end? lower the back? (a longer bike is more stable tho yeah)
when that feeling eventually wears off at a later date, it can be found again with a little huff of nitrous
Stuart Racing
N.H.R.A . Dragracing.
posted April 27, 2009 06:03 PM
I don`t know if you already did this , but I always raise the forks into the triple tree`s an inch or so to shorten the forks and it might stabilize the front end some....I don`t have a stabilzer on my 02 and run mine all over the mph gauge without even a wobble....My tubes are up in the tree`s 1.5 inches...Good tires all around, stiff rebound....(40 psi in front tire)...JMO....Thats my setup anyways....Be carefull with yours....
P.....
BALTIMORE410
posted April 27, 2009 06:33 PM
how do u raise the front.....imma look into this the bike rips i mean rediculous but man if i didnt lift weights the shake woulda thrown me off to the side of the road.... imma take pics to show u guys what the forks look like
BALTIMORE410
posted April 28, 2009 06:09 AM
BALTIMORE410
posted April 28, 2009 06:21 AM
Stuart Racing
posted April 28, 2009 06:43 AM        Edited By: Stuart Racing on 28 Apr 2009 14:45
Thats about what I have Steve.....What speed does it start shaking/wobbling.....The adj. above your finger is way up...Mine is about 1/2 what you have showing....Try screwing that down to half way....Front tire ok????Good luck with it...
140 to 180...just re read it....
BALTIMORE410
posted April 28, 2009 07:54 AM
how do u adjust it with the flat tip screw driver right on the very top?
Stuart Racing
posted April 28, 2009 09:32 AM
17 mm wrench or socket.....Count the lines on the side and make it the same on both sides.....
Rock4173
posted April 29, 2009 11:24 AM
When they put it back together did they tighen the steering stem tight enough?
BALTIMORE410
posted April 29, 2009 06:42 PM
I brought it up like u said to do paul and man what a difference way less wobble now i can really lean it hard comming in the corners and really crack open the throttle comming out as well.....i luv it......and what do u mean by steering stem rock??
Rock4173
posted April 30, 2009 06:39 AM
The head bearing nuts under the top yoke that secures the bearings and keeps the required tension on the bearings to keep the whole front end from moving around on you.
2000redrocket
posted May 01, 2009 11:00 AM
make sure you did not slide the tubes up past the machined area on the top clamp area. for my 00 about 3/4" is all i feel i dare go past cause i am going too far up into the taper. my tubes get thinnerbelow the stock clamp area and u wull not get the top clamp tight enough before the clamp is metal to metal. be carefull
0.25427389144897 seconds processing time
