BIKELAND > FORUMS > ZX12R ZONE.com > Thread: just checked clutch NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted April 12, 2009 08:05 AM
just checked clutch
well no cracks in basket. stack was 56.84 back plate to front plate in basket 2 springs on.
looks like i need to add some hight to it for this year.
going to also machine the basket notches a little bit more. clutch was on the dry side yet. this time i am going to not do it free hand. got someone i fly with has nice equipment.
Stuart Racing
N.H.R.A . Dragracing.
posted April 12, 2009 11:06 AM
How`d you get a measurement of the pack with it in the bike....
I`ve been taking mine out every time....
2000redrocket
posted April 12, 2009 12:10 PM        Edited By: 2000redrocket on 12 Apr 2009 20:12
with my digital calipers on the footpeg side of the basket say 8 ocolck i can get the point in the back and then on the outside. then figure out how much material is on the plate back half and front half and add that also. now i am at 56.8xxx before you take the half of the friction so in retrospeck i am good.
thanks for asking it has been a while since i did this and forgot the caliper is going to miss the friction material thickness on half of each end plate.
i just got sick of doing every friction plate 3 times and averaging it when i really wanted to know the compressed hight anyway.
stuart can you call me sometime to talk about your bike as it was with the lockup i got from you to go in my short bike. 717-383-7354
posted April 12, 2009 06:26 PM
i used to measure them all too, then i switched to just measuring the whole stack. grab it in one hand, give it a squeeze and put the calipers on it. now i just check the clearance with the lock up arms to the pressure plate. soo simple. you dont even need to know stack height with a lock up, you know exactly how much to add or take away by checking the clearance with feeler gauges. you dont even need to pull anything except the cover to check that all is well
2000redrocket
posted April 12, 2009 06:46 PM
scott that will be the next step. i am more aware of what i am doing with the clutch and want to see what i can accomplish this spring. i wish pm worked i can not remember what stuart said about just putting it on as so with 3 stock springs.(some of it i remember)
posted April 12, 2009 08:43 PM
you should get a set of the light duty double stack springs from mtc. way nicer to work with(that reminds me i gotta measure one for Keith...) i forget exactly how Nox put it, but they react to shims more linearly i believe. plus they are short, so taking the snowflake of is much nicer
Stuart Racing
posted April 13, 2009 06:05 AM
Aaaah, I always thought about doing it that way ,but didn`t think I could reach the back good enough....I measure the way Scott does it....Just squeeze the all together....
Glad you got the lockup...Hope you`re getting good use out of it,(maximum use)....Looks like the MTC light springs are the way to go .....Get a set, and a set of alum. bolts while your there.....Cool, thanks for the #, I`ll give ya a call.....
Paul....
0.24343299865723 seconds processing time
