BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Bearstacks Please NEW TOPIC NEW POLL POST REPLY
Ballisticzx12r
& Deals Gap Board Member
posted September 23, 2002 09:58 AM
Bearstacks Please
I would like to purchase a set of bear stacks, is there anyone in the states that has them.
I want a complete kit. I think Vince had some but it seem they where not complete.
Thanks,
Bart
Be fast and Be safe
  Ignore this member    Click here to visit BallisticZX12R's homepage.
harryzx-12
posted September 23, 2002 11:16 AM
I believe orient express has them , Bart.
posted September 23, 2002 12:36 PM
Here is the "Word" In them! They are "Not" in a "Kit" form! They "Now" come with the "0" Rings not mounted! YOU!! must buy your own allen 6 mm bolts!
Use Grade 6 to 8 "Without" the ridges (usually found in Grade 10 to 12 which have "LARGER HEADS" than the smooth head bolts)! You need 8 - 6 mm smooth head allen bolts that are 20 to 25 mm long! Either will be "OK"!
The "ONLY" Person that has them for sale in the USA IS Orient Express Period!!!
posted September 25, 2002 11:24 AM
Since I used 25 MM Length Bolts and saw about 5 ot 6 MM Sticking "Through" the nut retainer, I felt that 20 MM Would be neater looking! I spoke to BA today who stated that you must use 25 MM! The 20 MM is not quite long enough to get started on "Both" Holes at the same time! Sorry for the wrong information, but I wanted yours to look better than mine! Now I know that there is "Nothing" I can do about it!
Red 12R Rocket
posted September 25, 2002 02:16 PM
I used M6-1.0 x 22mm. PERFECT fit. End of discussion!!
posted September 25, 2002 03:39 PM
22-MM! You da man!! Now I got to look or cut mine 3 mm's
vozizm
Got Nothing Witty To Say
posted September 25, 2002 04:33 PM
damn i want some stacks ..but cant get past price...can help im a cheap SOB...
ninja12
posted September 26, 2002 09:00 AM
organize another group buy.
vozizm
posted September 26, 2002 09:13 AM
im not the organizing type plus vince hill did it once and said it was a pain in the but getting folks together....
VOZ
Red 12R Rocket
posted September 26, 2002 11:51 AM
I doubt you can do the "group buy" thing anymore. BEAR Engineering entered into some sort of an agreement with Orient Express. It is my understanding that Orient Express is the ONLY place you can get BEAR stacks from in the U.S.. So, I don't think Pierre will be sending any to the U.S. unless they are going to Orient Express!!
posted September 26, 2002 04:02 PM
"CORRECTAMUNDO"!!
posted September 27, 2002 07:36 AM
Hey man, I eat meat, I just don't dig pork.
vozizm
posted September 30, 2002 12:10 PM
Are bolts used Stainless Steel?...
VOZ
posted September 30, 2002 01:09 PM
The Cheapest possible! No strength needed! The Grade 6 to 8 have the smallest heads and work best!
moodybluezx12r
posted September 30, 2002 03:40 PM
orient express...wants $250.00...
Raleigh, NC
Ride it! Like You Stole It!
  Ignore this member    Click here to visit moodybluezx12r's homepage.
vozizm
posted September 30, 2002 04:12 PM
vincent... is rust not a factor with the install?... I WANT MY STACKS NOW!!!
VOZ
moodybluezx12r
posted September 30, 2002 10:16 PM
voz..you think $250.00 is too much for bear stacks?
Raleigh, NC
vozizm
posted October 01, 2002 09:40 AM
I STILL WANT MY STACKS!!!
posted October 01, 2002 01:34 PM
The Weaker Grade 6 to 8 Bolts are either Nicad or Nicad II Plated (Silver or Gold color) which is rust Proofing!
Stacks are now a Must Have addition for the "Serious" Go fast person! To me, the Pipe is #1 the PC3R is #2, BMC or K&N are #3, Bear Stacks are #4, Dyno Time #5, New Seat #6, Windshield #7, Raising the HandleBars #8, CF Rear Hugger #9, New Ohlins rear shock, #10 and #11 is a Steering Dampener! My #12 is 02 Mirrors!
Red 12R Rocket
posted October 01, 2002 02:24 PM
Just being a picky fuck here, but metric hardware does not use nomenclature like "Grade 6 to 8". Metric hardware comes in different classes (ie. class 8.8, class 12.9).
posted October 01, 2002 04:23 PM
SO you are saying that there are 2 grades with some of the "Numbers" I used "8 & 12" and are you also saying that the 8.8 is weaker than the 12.9?? would you also say that the 12.9 is usually Black from the heat treatment and usually has ridges around the outside?? and would you say that the 8.8 weaker bolt is usually silver Nicad which has no ridges and therefore smaller head?? OK!! Now when I was in school, Grade was the level of knowledge and Class was usually the subject in the grade! First comes the Grade and second comes the class! So if a dummy like me walked into a fastner store and asked for a 6 mm bolt that was 22 to 25 mm long and was not stronger than a grade "8" , do you think they would give me a 12.9 "Class" bolt??
In 59 years, I have never had that happen, but I will be sure to let you know when it does! All I was trying to get across was to order the weakest bolt with a rating! Since I do not know everything, and there may be a 6.6 or a 7.7, or 3 marks or 6 marks or no writing vs some writing, I tried to make sure the understanding was Less Strength was better than more! I try not to talk in any technical terms if possible here! Everyone already says that I sometimes speak down to people, so I try to give information with a little technical jargon as possible! If that is OK with you! (You can use stainless)
vozizm
posted October 01, 2002 04:26 PM
ME GOT
1] Muzzy SS full System with Ti can
2]PcIIIr
3]BMC
4]Muzzy Block Off's
5]Yellow Box
6]17t
7]Muzzy Fans
8]Water Wetter
9]Muzzy Lowering Links Middle Hole
10]Front Lowered 1 3/4
ME NEED
1]BEAR STACKS
2]Custom Map
3]Heli Bars
4]Scotts Damper
1]Why The Seat?
2]Why The Windsheild..
Hook a brother upwith some STACKs holmes..PLEASE..
As Always GRACIAS...
moodybluezx12r
posted October 01, 2002 04:45 PM
guess i need to work on getting them dam stacks
Raleigh, NC
vozizm
posted October 01, 2002 04:49 PM
Yo! Moody if VincentHill Hooks some brothers up....we will be in bizzness
moodybluezx12r
posted October 01, 2002 05:03 PM        Edited By: moodybluezx12r on 1 Oct 2002 18:16
yeah..now, i need that web site for the yellow box... ..you get any response from your e-mail sent to the express?
Raleigh, NC
0.45920705795288 seconds processing time
