BIKELAND > FORUMS > ZX12R ZONE.com > Thread: CRAZY IDLE!!!! NEW TOPIC NEW POLL POST REPLY
CARLOS
posted September 23, 2002 08:44 AM
CRAZY IDLE!!!!
HELP DOUG M. OR ANYONE?
I INSTALLED MY MUZZY BLOCK-OFF PLATES PER INSTRUCTIONS AFTER INSTALL. I NOTICE THE BIKE IDLES TO HIGH. WENT TO MAKE ADJUSTMENT AND THE IDLE ADJUSTER IS BACKED ALL THE WAY OFF (NO MORE ADJUSTMENT) WHAT CAN I DO TO GET IT TO ADJUSTED BACK TO NORMAL IDLE? DO I NEED TO ADJUST THE THROTTLE CABLES, IF SO HOW? NEED HELP ASAP!! THE WEATHER HERE IS IN THE HIGH 70'S AND LOW 80'S. IT IS BEAUTIFUL OUTSIDE.
THANKS
CARLOS
zx1012r
posted September 23, 2002 09:46 AM
Sounds lika a vacuum leak. Check the hose you disconnected that goes to the throttle bodies and make sure it is plugged. Changing the block off plates alone should not change idle.
posted September 23, 2002 02:55 PM
Carlos,
The large air valve that "Y"s to the stock KACS plates has a small rubber vacuum hose connected to it. You need to plug this, otherwise you create a vacuuum leak. The block offs themselves have no bearing on idle speed or mixture.
Doug
CARLOS
posted September 24, 2002 07:11 AM
THANKS FOR ALL THE HELP GUYS
CARLOS
0.22557210922241 seconds processing time
