BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Sealing the RamAir NEW TOPIC NEW POLL POST REPLY
kiwi12
posted March 10, 2009 05:23 AM
Sealing the RamAir
Ive been spending a bit of time sealing my RamAir ,
and today after i had removed the front end to check my steering head bearings,
i noticed that there is a hole.(15 to 20 mm) going through to the air box about half way down inside the steering neck,
should this be sealed aswell? and is there any other little surprise,s like this, that I should be aware of ?
cheers
what is going on in here?
lowflyer
posted March 10, 2009 04:12 PM
Yes! Seal it. It is definitely open to the out side. You probably saw the two holes on the side of the airbox that the tank and trim pieces attach to, and the air filter slots can leak, too. the airbox drain in the left rear corner, and the breather hose under the tank, the PAIR(?) valve in the floor of the airbox in front of the filters. The velocity stacks can be another spot. After sealing all of those, it will hold quite a bit of pressure.
kiwi12
posted March 10, 2009 05:10 PM
Thanks for the reply,
im sealing as we speak, lol
posted March 10, 2009 08:05 PM
and lowflyer would know! how many psi in your airbox?
lowflyer
posted March 11, 2009 05:19 AM
max of 20psi right now...more to follow.
TRNorBRN6001
posted March 11, 2009 06:11 AM
20psi VERY NICE!!!!! I need one of them Airbox pressure-izers!!!!
TFA 200MPH CLUB MEMBER!
lowflyer
posted March 11, 2009 12:11 PM
No problemo! I will even help with the install!
kiwi12
posted March 11, 2009 02:25 PM
Ive sealed till my little heart is content,
I removed the kleen air, (awhile back) and sealed everything,
I sealed the crankcase breather going into the airbox, and re routed the breather hose to the back of the bike.
and everything else lowfler has suggested.
My mods to date,
bolt on muzzy
muzzy advance plate
muzzy box
sealed Ramair
DNA air fliters
kleen air removed, and block off plates inserted
rewired 1st 2nd and 3rd into 4th gear on the ECU
0.26123118400574 seconds processing time
