BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Velocity stacks? NEW TOPIC NEW POLL POST REPLY
Liquid Rhino
Loving Life! God Bless!
posted March 06, 2009 05:32 AM
Velocity stacks?
Anyone out there have any advice on velocity stacks? I just installed PCIII and I'm going to get the bike tuned. I want to install the stacks too. I also purchased BMC race filters...??? ANy advice as to what to do next? Thanks-
TRNorBRN6001
posted March 06, 2009 06:26 AM
I like Bear Stacks, they are perty! Vincent Hill is the person to talk to.
Gary
TFA 200MPH CLUB MEMBER!
posted March 06, 2009 09:37 AM
a full pipe would be the next step not stacks. more hp gain per dollar. i think you had a stock pipe anyway?? you were interested in that Ti Muzzy slip on awhile back then i never heard anything else??
woppi
posted March 06, 2009 10:42 AM        Edited By: woppi on 6 Mar 2009 18:43
Bear Stacks ! ------ i like them !!!
Muzzy Short
Muzzy NOS
my Wet System
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
NOX
PMRA / TMRC Super Street 4022
posted March 06, 2009 10:59 PM
I run the bear mixed.
I would like to try all shorts though........, since I leave at 7000.......,, I even have the purple ones...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Liquid Rhino
posted March 07, 2009 05:11 AM
As for the Muzzy Slip on I ended up with a full exhaust I got it for $400. I dont know what my HP is currently because of the FI light that I've never been able to the pull the code. I got the phukin thing to read off the code once and then nothing. I thought I reset the ecu, but nope it still comes on. Im about to go out and get a new cdi. until I get that fixed i cant map or dyno correctly, so I'm getting everything so that when i'm ready I can install and ride ASAP.
Do the short stacks bog out if you ride everyday? Do you need to be at a high rpm when you start off?
Liquid Rhino
posted March 07, 2009 05:18 AM
Is there a shop anywhere in Miami FL that can do a proper repair without blowing smoke up your A$$? I just wanna drop off my bike and let you see what the problem is and fix it! The Shops I've been to so far here just want your damn cash!!!!!!!!! %&^*(##!!
posted March 07, 2009 07:18 PM        Edited By: KZScott on 8 Mar 2009 03:19
the stacks dont remove any power anywhere(no bog!). the short ones add a couple hp up top, mixed, mid range. long, bottom end
i forget exactly where they are in fl, but check out Ace performance
NOX
posted March 08, 2009 12:14 PM
anyone have a set of all shorts, they would want to swap two longs for two shorts...., bear only.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zxboy
posted March 10, 2009 11:21 AM
Nox...Whats up???
I've got a set of all short bear stacks in mine. I'll swap out with you in the interest of science!! It's a question of when I can do it...I'm on the road all the time lately. I think
I still got your number I'll give you a call.
I got some news for you...I finally broke into the 8's this weekend up at the AMA race in Valdosta. Ran a bunch of 8.97-8.99's.
I changed the Muzzy sidewinder megaphone to a Murry prostock meg...It's aluminum , no baffle, lighter and a smaller outlet diameter. I also started running the bike dry of coolant !! the end result was the bike is about 15+ pounds lighter. It's now 490lbs ready to go.
I was happy with those numbers.
sorry for the thread highjack..... Later, Roy
posted March 10, 2009 03:44 PM
wow... thats brave, i wouldnt run it dry unless it was a solid block...at most no rad just a hose....
zxboy
posted March 11, 2009 12:25 PM
It's not that brave.....me and 2 other of my zx12 buddies have been running dry for a little while. Some of the promod / top gas busa guys have been running dry for some time too
NOX
posted March 11, 2009 03:46 PM
Yeah, you do not run, totally dry...., leave just a touch in for the pump.......
I know some fast guys who do it.......
15 lbs......WOW.
Light bulb blinking over nox's head........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted March 11, 2009 03:47 PM
Yeah, with the bars, you have extra weight......., 490 is good for your bike for sure........
congrats on the 8s.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted March 12, 2009 12:12 AM
15 lbs......WOW.
why not remove the impeller? then its just an oil pump
zxboy
posted March 12, 2009 04:00 AM
Scott,
I do run mine completely dry....I'm fabing up a block off plate right now, so yes I'll have just a oil pump on the shaft.
NOX
posted March 12, 2009 02:09 PM
Roy, about how much did you pick up.........
This would be nice for me to try when I want to go stupid quick.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted March 12, 2009 10:58 PM
zxboy
posted March 13, 2009 06:16 AM
Nox,
I picked up about 6-7 hundreths. But that was 2 different tracks.....so I'm not sure how accurate a comparison that is. I'll be returning to my home track next weekend for a points race, That'll be a better comparison....I'll let you know. It may pick up even more ??
NOX
posted March 13, 2009 01:52 PM
Thanks Roy.
Give me a call on Sat, I wont have much time to talk, but have some info for you on that slider.....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted March 16, 2009 06:38 AM
Thanks Roy.
I would say send me a PM! are you on any other Boards that the PM Works?
posted March 16, 2009 10:00 AM
why not just email?
posted March 16, 2009 01:07 PM
Well, Scott...you know, not everyone wants to post up their personal email...
I'm losing communications with a lot of people on here; I don't expect them to post their email info, and I prefer not to post mine everywhere.
Plus, with emails you never know what is going to wind up in your spam box...
Anyway....whatever.
posted March 16, 2009 01:31 PM
Anyway....whatever.
ZACTLY!! WIth an EXACT in front of that!
posted March 16, 2009 02:24 PM
true, but its pretty easy to set up a free hotmail account for your bike forums. takes about 5 min
0.26181101799011 seconds processing time
