BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Modify 2000 ZX12 inner hub? NEW TOPIC NEW POLL POST REPLY
jnybbad
posted January 27, 2009 01:33 PM
Is it possible to modify, drilling oil holes, the 2000 ZX12 inner hub so it oils better? Or is it smarter to just upgrade? I have heard that newer years will fit the 2000 but are updated.
NINJA12
posted January 27, 2009 03:31 PM
yes you can modify the 2000 hub, but It's to easy to just get the 2002 up .
posted January 27, 2009 04:41 PM
I drilled dads out to match my Muzzy drilled hub, allong with the flat spot mod to the pusher, it worked great
jnybbad
posted January 27, 2009 07:49 PM
Can you explaine the flat spot mod?
canadian mike
posted January 27, 2009 07:58 PM
id like to know myself
01 zx12
03 TURBO BUSA
jnybbad
posted January 27, 2009 08:45 PM        Edited By: jnybbad on 28 Jan 2009 04:52
I found the information for the flat spot mod. I just have some questions as I couldn't find pics and everyones terminology is a little different.
To cross drill the pusher shaft I measure 1.65" up from the part of the shaft that seats deapest into the motor?
I then cross drill .040 holes behind the needle bearing flat?
BEHIND meaning towards the inner motor or between the bearing and the shaft so that the oil squirts onto the needle bearing and then the clutch?
slykittycat
posted January 27, 2009 11:19 PM
looks like ill be watching this thread for info too lol
  Ignore this member    Click here to visit slykittycat's homepage.
NINJA12
posted January 28, 2009 08:06 AM
What did you use to drill it. Pic?
posted January 28, 2009 10:15 AM
you cant drill it unless you have a special drill... edm i think if i remember right. way easier to just grind the flat spot. ill post some pics later when i find them
jnybbad
posted January 28, 2009 10:56 AM
That would be great, Thank you! I just read up on EDM, looks like the flat spot will be easier.
posted January 28, 2009 03:11 PM        Edited By: KZScott on 28 Jan 2009 23:18
ok here you go,
the purpose is to get oil from the trans shaft to the clutch pack. Muzzy has a kit that modifies a sleeve and the hub (hard to copy without maching equipment) or you can drill the hub and do the flat spot or drill the pusher.
I had a Muzzy modified sleeve and hub in my bike when i got it. I copied the drill pattern in the hub where the clutch pack goes for dads hub, and did a flat spot to the pusher. its very hard to copy the machining by the sleeve/hub nut on the hub. hes running an MTC lock up so his pusher is different than the stock ones, so ill include a pic of how to modify a stock one too
dont grind too much off or you will have too much oil in the clutch robbing power, and it will lower the oil pressure. start with a small amount and work up untill you no longer have dry clutchs.
jnybbad
posted January 28, 2009 03:26 PM
Thanks for the help, i got it now!!
jeremy_kokwk
posted February 01, 2009 10:58 PM
so if i want a cheaper and easier method, i just get 2002 up inner hub and fix it into my 2000 clutch? or i also need to get 2002 up clutch basket too?
ZXLNT
posted February 02, 2009 05:19 AM
Just replace the clutch hub...
Stuart Racing
N.H.R.A . Dragracing.
posted February 02, 2009 03:02 PM
Can`t cross drill mine, it`s solid.....But I can flat spot it....That`ll help...
jeremy_kokwk
posted February 04, 2009 05:06 AM
oh then anyone have a 2002 up clutch hub for sale???is the hub the picture with a red arrow?
ZXLNT
posted February 04, 2009 11:10 AM
The hub is the first picture in the post..
jeremy_kokwk
posted February 04, 2009 08:35 PM
oh i see ..... then the last pic, do i need to get that pin?
ZXLNT
posted February 06, 2009 03:25 AM
Use the stock puller and have it EMD cross drilled and then flat spot it as shown..
twista
" Get up, and Stay up ! "
posted February 06, 2009 08:31 PM
Hey Scott,, in reference to the puller shaft pics? one seems longer than the other,, also one looks like its been hollowed out or is that a figment of my imagination,, and what does the notch mic at?
posted February 06, 2009 09:18 PM
it is. the long one is an MTC. you need a longer one because the cover is spaced out on a lock up to make enough room for the snowflake.
the stock one and mtc are hollow, the mtc is also thinner except at the end. it reduces binding if theres any play side to side (but the bearing insert in the cover pretty much gets rid of any anyway). see how the stock one is worn by the tip of the trans shaft?
i didnt mic it, but i would start by making it 1/8 in across for the length of the green section in the pic. if you still have problems with a dry clutch grind away a bit more. i did this for a buddy at the track with a busa and had to do 2 pretty big flat spots. you may only need a small one, but go in small steps so you dont take away too much.
a lock up the way it comes from MTC:
fyi, dont set it up with that much weight lol
jnybbad
posted March 19, 2009 07:09 PM        Edited By: jnybbad on 20 Mar 2009 03:28
I got the 2002 inner hub. It has 6 holes on the bottom but no holes along the ridges as in the above pics. Would it help to add those holes as well?
posted March 19, 2009 07:35 PM
Last i heard, Muzzys was using the 02 hub for their clutch kit now, so i would say yes
jnybbad
posted March 19, 2009 09:32 PM
Cool, thats what I did. Has anyone ever had the inner hub fail? I just ask because I see that Muzzy makes billet hubs for Suzuki but I didn't see it for the Kawi. I drilled the holes, per the pics above. I got off a couple of grooves on set of holes but other than that Ill try it out as soon as my basket gets back. Thanks for all the input.
If I never said before, this engine is in a custom sand rail that i recently built. It definately screems and I hope these mods will keep it together.
posted March 20, 2009 08:35 PM
that looks like a fun toy!
ive never heard of a hub failure, but lots of guys blow up the stock basket. i think the billet piece for the zuks is just to eliminate a cusion or something. lots of guys just weld them solid. ours is allready solid
0.49675393104553 seconds processing time
