BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2004 zx12r 185mph governer NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted February 11, 2009 12:56 PM
Been looking around for one of those boxes that removes the bikes governor and I noticed most of the stuff out is usually for 2001-2003 (2000 there is none) well what about the 2004-2005 bikes????
  Ignore this member    Click here to visit BALTIMORE410's homepage.
posted February 11, 2009 03:06 PM
niko g pack
BALTIMORE410
posted February 11, 2009 03:48 PM
Good look kz....
woppi
posted February 11, 2009 11:37 PM
Muzzy Bonneville Box ???
http://www.muzzys.com/MZPM-K12/index.html
pic -- from muzzy website
nico g pack
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
woppi
posted February 11, 2009 11:39 PM
website:
http://www.nikkoracing.com/gpack_tarifkawa.htm
woppi
lowflyer
posted February 12, 2009 04:49 AM
You can also send your ecu to Sal@Ace. he can derestrict it and change other variables, such as timing and max RPM, for about the same price. Just got mine back last week.
posted February 12, 2009 08:30 AM
The Bonneville box does not work for the 04-05. Nor can the ECU's for those bikes be reflashed, as far as I know.
Phantom13
posted February 12, 2009 03:40 PM
Correct Shane.
The 04-05's use a 32-bit ecu instead of the 16-bit ecu found in all other years. The 32-bit ecu IS flashable, but a donor ecu would be needed for "hacking".
So far, nobody has given up a sacrificial 04-05 ecu for dismemberment (Yes, the first ecu will be destroyed in order to gain the ability to reflash others)
The Bonn box only works on the 16-bit ecu's..... the 04-05's require a SPEEDO HEALER to bypass the limiter from what I've been told. Only bad part is that your speedo will be "off" since you need to set it so that the ECU thinks you're traveling slower than 185mph when actually going over 185mph.
"The only place Success comes
before Work is inside the Dictionary."
  Ignore this member    Click here to visit Phantom13's homepage.
Fasttimez
posted February 12, 2009 06:43 PM
I installed a Niko-G Pack on my 05 ZX12R and it works great. The only thing that sucks is nobody in the states seems to have one so I had to order mine from the UK. It's actually about $50.00 cheaper from the UK and that's including shipping.
posted February 12, 2009 07:13 PM
http://www.bikeland.org/board/viewthread.php?FID=1&TID=30915&set_time=
shiphteey
posted February 13, 2009 01:17 PM
The 04 ZX12 (1427cc) that Rick built that went 203.6 mph at Maxton
I believe he had the speedo healer in it and turned it down to go over 200 (or 186 actually). I believe you can disconnect the speedo and make a pass but that afterwards the FI light comes on.
A.
Gemini Motorcycles
whitehendrix
fails!
posted February 13, 2009 10:03 PM
theres a way to make your own bypass.. i think RR originally came up with it? using .. i wanna say the tach signal and a voltage-shifting circuit to match the signal voltages (from 5 to 12V).. looked uber simple..
http://www.i-hacked.com/content/view/178/45/
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
posted February 13, 2009 11:42 PM
pretty sure thats only for bikes that can use the bonny box whitey.
Fasttimez
posted April 15, 2009 02:54 PM
Here is the company I ordered my Nikko G-Pack Over 3 racing module from. It's in the UK, they also have alot of great stuff not found in the USA.
www.intobikes.co.uk
Stuart Racing
N.H.R.A . Dragracing.
posted April 15, 2009 03:14 PM
Heal Tech. Electronics
www.speedohealer.com
Just put one on my bike...
0.34305787086487 seconds processing time
