BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Changing clutch question? NEW TOPIC NEW POLL POST REPLY
jnybbad
posted January 27, 2009 09:39 PM
I will be replacing my clutch on my 2000 ZX12 soon and have a question. I have a manual and read the clutch section and am a little confused. They mention using a tool to line up the inner hub with the basket or something. I also read a post in the past that mentioned the importance due to the oil pump. The instructions are confusing can someone explain the purpose and what needs to be done in english for me???
woppi
posted January 27, 2009 10:51 PM
what do you want to do ??
change the fibre + steel plates ???
or change the clutch basket + inner hub also ?
tell us ?
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
jnybbad
posted January 28, 2009 10:51 AM
I am putting in the muzzy kit with inner hub and all plates and fibers. I have done a lot of clutches and none required a tool to line up the inner hub and basket. However the manual seems to be saying this is what i have to do?
twista
" Get up, and Stay up ! "
posted January 28, 2009 11:29 AM        Edited By: twista on 28 Jan 2009 19:31
no special tools needed even if you were gonna change the basket! just a bar to lock the wheels,, socket for the cover and cable,, socket and breaker w/pipe for the basket nut and allen for the springs,, and thats it bubba maybe a torque wrench to put it back to spec,, and a small screw for the collar to slip the basket on without fighting it on the way out
posted January 28, 2009 01:47 PM
you are probly refering to the clutch hub holder. you can make one very easily with a couple old steels and some scrap metal. weld the steels together(lined up) and put a handle on them. then you can take the big hub nut off
jnybbad
posted January 28, 2009 03:23 PM
That may be what they were talikng about. It just seemed odd that the manual made a point about stating that a certain part of the hub had to be facing forward. This may just be needed for the Kawi tool to work??? i have a clutch holder, Thanks for the info!!
woppi
posted January 29, 2009 02:39 AM
yes !!
like this one --
woppi
jnybbad
posted January 29, 2009 08:51 AM
I am making one of those!! Mine is the old vice grip style that always finds a way of popping off and marring up the hub.
twista
posted February 06, 2009 08:20 PM        Edited By: twista on 7 Feb 2009 04:20
i wrap a towel around a HARD BAR and prop it thru the wheel then i take a socket and breaker bar and then slip a floor jack over the breaker and i crack it no prob! by myself!
nice tool scott!
NOX
PMRA / TMRC Super Street 4022
posted February 09, 2009 12:56 PM
impact.........
hold the fibers with your fingers......., works like a charm
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
2000redrocket
posted February 09, 2009 03:44 PM
yes the impact is the way. i use a drilbit and put it through the hole to keep the back gears aligned on basket. it worked.
jnybbad
posted February 25, 2009 10:03 PM
What needs to be ALIGNED?
NOX
posted February 26, 2009 07:32 AM
nothing to remove the hub.......
that tool is cool though.....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
almost_les
posted February 26, 2009 08:41 AM        Edited By: almost_les on 26 Feb 2009 16:45
if you're only doing a new indder hub you don't need to worry about the special tool to keep the basket gear alligned.
the inner hub and basket don't need to ba alligned.
the tool is only needed when installing a basket. once you get everything opened up you'll notice that the basket gear is two separae gears adjacent to eachother with some springs trying to make them not want to line up. this makes it so that there is no backlash with the crank gear since it is being contacted by both gears, one on each side of the teeth. there is a special tool that is inserted into a hole in the bottom of the clutch basket to line these gears up making it posible to mount on the bike. otherwise the basket would not be seated all the way in and now mesh with the oil pump gear. this part needs to be facing toward the front of the bike so that the end poking out doesn't hit the cases. most guys just jab a screwdriver in there.
you're only changing the inner hub so you don't have to deal with all that stuff.
hope that helped
oh, and make sure its an OEM clutch pack
jnybbad
posted February 26, 2009 01:04 PM
hope that helped
That was exatly what i needed, thank you. I will be pulling the basket as i purchased new bearings as well.
0.28670787811279 seconds processing time
